12-28-2010, 09:42 PM | #1 |
ou mai gad
Drives: SW 2SS x2 Join Date: Feb 2010
Oil Pump :: HP vs HV
I'm getting ready to tear apart my M6 car, just missing the oil pump.
Normally I would let the stock one live for such small mods but with some people having problems with them I was going to order a melling one, however the vendor asked High Pressure or High Volume and I froze..... Builders any help is appreciated, or any other brand you may suggest?
12-28-2010, 09:48 PM | #2 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
High volume is my choice generally. Especially when building a real radical build where I run the tolerances a little on the loose side.
12-28-2010, 10:19 PM | #3 |
ou mai gad
Well everything is going to stay stock.. it's just heads/cam/rod bolts..
12-29-2010, 11:15 AM | #4 |
Drives: 2010 Black M6 RS/2SS Join Date: Oct 2009
Most people run the Melling High Volume unit 10296 with the standard pressure spring, that's the one I'm going use, I think.
The Melling 10295 is like a stock unit standard volume that comes with a high presure spring 10lbs more than stock at all RPMs. Either way Mellings are real good units
10 Blk/Blk RS/2SS w/CGM Stripes
ADM H/C/I M6 480rwhp 435rwtq FE4 LCAs w/Pfadt ZL swaybars Diff bushings Trailing arms Drop springs |
12-29-2010, 12:23 PM | #5 |
ou mai gad
Well I chickened out and bought a Katech one...
And reading about horror stories of ARP rod bolts I bought some Katech ones too..
12-29-2010, 12:30 PM | #6 |
Drives: 99 Camaro SS, 79 z28, 70 GTX Join Date: Oct 2009
Melling HV 10296 is all we use/HKE in our speced engines.
Ported and shimmed oem OP's are not what we recommend to our engine customers. They are a big money maker for the people selling them, but they are not what we would use. I've sent back 2 this month alone to the customer and provided them with the Melling instead. |
12-29-2010, 02:14 PM | #7 |
ou mai gad
Maybe I talked to the wrong people but they said that the 10296 was better used for a higher tolerance engine.
They also said the HV could dry the oilpan in a sustained high rpm lapse. I know a drag race takes 10 secs (toretto style) but imagine going 155mph for 10mins... Anyway No one sells a bad product I guess...
12-29-2010, 03:01 PM | #8 | |
Drives: 2010 Camaro 2SS/RS Join Date: Sep 2009
What up man? How are your builds going? BTW, the 408 in the Silvy has a shimmed LS6 pump and the Camaro a stock pump. No issues with either and they both have heads/cam and other bolt ons.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock 2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo |
12-29-2010, 03:17 PM | #9 | |
ou mai gad
Cul to Maz at 270, I bet you had some escort there The builds are going ehhh slow... About to start the M6 car just now and the A6 car is on the garage without engine and the trunk full of parts :emoticon7: How is the red camaro doing? any runs yet?
12-29-2010, 03:35 PM | #10 | |
The Orange Camaro was wrecked coming home from the track in the rain on the DR's. Haven't raced it since I ran the 10.9 but were hoping for 9's next. The Silverado should be done soon and I will be driving it down there early next year probably in February. The Hemi should be done soon too.
12-29-2010, 04:50 PM | #11 |
Drives: 1999 Trans Am Join Date: Jul 2009
We always use a ls6 style pump, ported and pressure raised in-house. Never a problem from a stock car to a 7200 rpm, 900 rwhp setup. Our engines are built tight though.
Similar Threads | ||||
L99 Lifters | Ohten | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 25 | 06-29-2010 09:33 AM |
Can we use the catchcan made for the G8? | HaZe_X | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 16 | 05-05-2010 10:35 AM |
Oil Change Ramp | mjlash22 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 17 | 01-21-2010 10:40 PM |
synthetic motor oil? | bigd1276 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 71 | 01-29-2009 12:28 PM |
Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 09:47 AM |
