Old 11-27-2010, 10:04 AM   #1
69307
69307's Avatar
Drives: 2010 2SS/RS Summit White Camaro
Rear Bowtie Removal on 2010
I'm wanting to replace the rear bowtie on my 2010 with SLP 'SS' badging. I've read on this forum that the 2011's and some of the "later" 2010's don't have guide pins. Does anyone know if/when GM quit using guide pins on the 2010's?
Thanks!
69307 is offline   Reply With Quote
Old 11-27-2010, 10:12 AM   #2
lightner75
LoneStar Camaro
lightner75's Avatar
Drives: 2010 cyber gray 2ss
mine was built 1-13-2010 and no guide pins
lightner75 is offline   Reply With Quote
Old 11-27-2010, 10:20 AM   #3
69307
69307's Avatar
Thanks Lightner75... Mine was built Oct 09 so I'm hoping they stopped using guide pins before that!
Old 11-27-2010, 10:34 AM   #4
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
Mine was built 5/13/10 and she does have pins :(.
Here's a cheesy DIY I made to see if you have pins.
RJT, 2SS/RS, M6, Black Int, Sunroof.
daphatgrant is offline   Reply With Quote
Old 11-27-2010, 10:42 AM   #5
wrbear
Banned
Drives: 2010, 2SS, IOM/CGM Stripes, 4/24/10
You could run a needle from the bottom up into the back of the bowtie and see if you hit resistance (use the pic above as a guide). Another way would be to remove the trunk lid backing (easy to do). Feel for it via the holes on either side of the back of the bowtie mount (in the trunk lid). GOOD LUCK!
wrbear is offline   Reply With Quote
Old 11-27-2010, 11:26 AM   #6
69307
69307's Avatar
Originally Posted by wrbear View Post
Attachment 187609
Thanks for the suggestions I'll check it out!!
Old 11-27-2010, 11:37 AM   #7
wrbear
Banned
Another suggestion. These holes are guides so you really don't have to remove anything from the back from my experience.
Old 11-28-2010, 09:02 AM   #8
dragonZ28
Drives: 2001 T/A, 2010 2SS/RS, 2006 Z06
If you remove the bowtie and you have the holes, you can cover them with different types of emblems. We make many items that will cover the holes.
There are also different colored decals which we "do not" make that also covers them. If you want.
Just offering suggestions.
dragonZ28 is offline   Reply With Quote
Old 11-28-2010, 09:08 AM   #9
69307
69307's Avatar
There are also defferent colored decals which we "do not" make that also covers them. If you want.
Thanks DragonZ28, I'll check out your website
Old 11-28-2010, 11:33 AM   #10
daphatgrant
June '10
This in black spread out a little more would look awesome, especially on SW
Like this
Old 11-28-2010, 11:53 AM   #11
69307
69307's Avatar
That definitely looks sharp!!!!
Old 11-28-2010, 12:49 PM   #12
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
There is a thread here somewhere that shows how to lower the inside cover on the inside of the trunk lid and look through a hole to see if the guide pins are present.
Found the link, check it out. http://www.camaro5.com/forums/showthread.php?t=104602
CAMARO WIKI Tran Wiki 66 04-22-2024 11:41 AM
Modern Camaro Performance Parts - www.PartsTaxi.com PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 10-06-2010 04:26 PM
2010 Blue SS for $32990 and we pay for your plane ticket! Mitsubishi in Syracuse Dealer Camaros for Sale 0 12-21-2009 12:42 PM
LM Performance, Spohn Camaro 2010 Tubular Rear Toe Links with Spherical Rod Ends. LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 01:44 PM
LM Performance, Spohn Camaro 2010 Tubular Rear Toe Links with Del-Sphere Pivot Joints LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 01:39 PM
