01-20-2013, 09:28 AM | #1 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
Protect front splitter from scrapping end of driveway?
What's everyone doing to protect the bottom of the front splitter from scrapping the end of the drive when you pull in and out?
My drive is a particular problem since is has a rounded curb instead of the more traditional cement cut out. In my SS I could avoid scrapping the bottom if I approached or came down at a sharp angle. This method didn't work yesterday with the ZL1 -- scrapped the driver's side edge the first time I pulled into the drive. I also scrapped the splitter coming down a friends drive with a relatively steep incline. At this rate I'll have a chewed up splitter bottom in no time. Any suggestions to protect it will be most appreciated.
01-20-2013, 09:33 AM | #2 |
BLOWN!!!
Blown! Full Bolt-ons!
01-20-2013, 09:36 AM | #3 |
Moderator
You should move, or give me your Camaro.
I have the same problem with my driveway. :(
Operation Demon//Buy at Invoice//RACECARWEAR RESPECT ALL CARS. LOVE YOUR OWN. warn 145:159 ban |
01-20-2013, 09:41 AM | #4 | |
Coupe Newbie
01-20-2013, 09:43 AM | #5 |
Drives: 2014 1LE 'Summit White' Join Date: Jul 2009
Bolt on a piece of metal to the bottom and paint it black...
01-20-2013, 10:01 AM | #6 |
BLOWN!!!
01-20-2013, 10:34 AM | #7 |
Coupe Newbie
Certainly an option. Wonder how a piece of metal will affect the aerodynamic balance of the car?
01-20-2013, 10:47 AM | #8 |
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega Join Date: Mar 2012
Cheaper solution
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
01-20-2013, 11:07 AM | #9 |
Coupe Newbie
Definitely a cheap solution. I don't think the city or my neighbors for that matter would be real happy if it altered the storm water run off on my street. That darn sewer grate at the end of my drive collects storm water for the entire cul de sac.
So far I like the Bridjit product because it allows the storm water to drain underneath it.
01-20-2013, 11:11 AM | #10 |
Drives: 2000 Camaro SS 2013 ZL1 Camaro Join Date: Jul 2012
01-20-2013, 11:25 AM | #11 | |
01-20-2013, 11:40 AM | #12 |
Here is the other pic. The work in this unit, is getting a angle on the guard. You do not want it to be a square corner or it will catch on something.
The front of it will be black also. I do have ten of them right now. Email if interested. John@gsimaviation.com |
01-20-2013, 11:41 AM | #13 | |
Drives: 2022 Camaro ZL1 Convertible A10 Join Date: Aug 2012
Somebody is going to fabricate a metal plate to help solve the problem. See the Camaro5 link below: http://www.camaro5.com/forums/showthread.php?t=265523 |
01-20-2013, 11:48 AM | #14 | |
It is going to be a cone washer you can put anywhere on the bottom to protect all the way across the splitter. Just replace them if you wear them out. I was not wanting to disrupt the air with the splitter guard all the way across. |
