Old 01-20-2017, 07:34 AM   #1
savage99ss
Im the boss
savage99ss's Avatar
Drives: 1999 Camaro SS
I smell coolant
Try to help me solve this. 1999 camaro ss. All stock minus headers and exhaust. 100k on the clock. I smell coolant from engine bay. No coolant on the pass floor. Does not appear to be droping coolant level on stick. I have checked under the battery at coolant bottle, no cracks. It does have a little white smoke in exhaust but not a ton. Does this sound like a head gasket? Expensive fix?
Camaro SS #0785 - 1 of 280 SS's that were pewter, auto, and T-Top - SLP Headers, LM1,Y-pipe, high flow cats, SLP Lid
savage99ss is offline   Reply With Quote
Old 01-22-2017, 09:21 AM   #2
Stew2000
Stew2000's Avatar
Drives: 2015 Camaro SS,2000 Camaro SS
Possible head gasket, you could run a bottle of stop leak through your radiator and see if that might resolve it.
2015 Summit White 1SS/RS-M6,NPP,Z28 CAI,ZL1 Pedals,Heritage grille, LT Headers,Vmax TB,1LE Steering wheel and shift knob
2000 Arctic White SS-M6,factory Hurst with short stick,Slp Lid,Cold Air and Loudmouth,SLP Bilsteins and Eibachs,UMI LCA,PHB,SFCs.
Stew2000 is offline   Reply With Quote
Old 01-22-2017, 03:11 PM   #3
ZL1C7
ZL1C7's Avatar
Drives: 2023 SS 1LE 10SPD/2015 SS 427 Man
x2 for head gasket.
ZL1C7 is offline   Reply With Quote
Old 01-22-2017, 03:14 PM   #4
ZL1C7
ZL1C7's Avatar
You can try and smell the exhaust (white smoke) also. It may have a bit of that same coolant smell. =headgasket
Old 01-29-2017, 11:55 AM   #5
King Nothing
Under a Peterbilt
Drives: Rogue, Durango and Camaro
Don't run stop leak!!!!!!! Pressure test the system first and then do a leak down test.
Sold-2006 Pontiac GTO
M6 1 of 475
353rwhp 353rwtq
Sold-2000 Camaro SS A4 Hardtop #867 of 8913
1 of 103 Bright Rally Red Hardtop SS A4 in 2000
2011 Camaro 2SS/RS M6 By Berger #11BC21
King Nothing is offline   Reply With Quote
Old 01-29-2017, 12:29 PM   #6
sherob
sherob's Avatar
Drives: 2015 SW 1SS/RS 1LE
+1... it'll cause more problems than it's worth.
“The Eagles and the Captain and Tennille ruled the airwaves, and we were the answer to it.” - Joey Ramone
http://www.camaro5.com/forums/picture.php?albumid=17325&pictureid=134228
sherob is offline   Reply With Quote
Old 02-01-2017, 12:05 PM   #7
savage99ss
Im the boss
savage99ss's Avatar
What would a pressure test cost?
Old 02-01-2017, 12:22 PM   #8
sherob
sherob's Avatar
Anywhere between $70 and $100...
Old 02-07-2017, 04:41 AM   #9
King Nothing
Under a Peterbilt
Depends on the kind and who you buy it from. My SnapOn pneumatic tester and truck adapter set cost me almost $400, but I use it almost daily at work.
M6 1 of 475
353rwhp 353rwtq
Old 02-07-2017, 12:05 PM   #10
savage99ss
Im the boss
savage99ss's Avatar
I guess I should have been more specific. How much would you charge me if I was in your area.
Old 02-07-2017, 12:35 PM   #11
King Nothing
Under a Peterbilt
I wouldn't charge anything.
M6 1 of 475
353rwhp 353rwtq
Old 02-07-2017, 01:29 PM   #12
savage99ss
Im the boss
savage99ss's Avatar
wish I knew someone like you in the Nashville area...
Old 02-08-2017, 04:17 AM   #13
King Nothing
Under a Peterbilt
I'm sure there are a few lol check on LS1tech in the TN area!
M6 1 of 475
353rwhp 353rwtq
Old 02-15-2017, 04:22 PM   #14
Cyber10
Cyber10's Avatar
Drives: 2010 Camaro 2SS/RS
You can buy a block test, pressure test, or leakdown test kit from NAPA for relatively cheap. Definitely under $100.
When I was chasing my coolant leak I bought a block tester and pressure tester, only to find out that it was sealed properly. Finally noticed a weird residue on the underside of my hood. Replaced radiator cap and no more leak. My best bet is that the cap wasn't sealing properly anymore and coolant was evaporating out, which would explain why all of my cooling system connections and tubing was always dry. Also the pressure tester I bought had a connection so you can test radiator caps, I think they're rated to hold 18 PSI? Mine wasn't holding even half of that.
I did however go and change my head and intake gaskets shortly after for safe measure, mostly because I had a hose break earlier that year and overheated the engine so wasn't sure what kind of condition they were in to begin with.
491 hp/438 tq
LS3 Conversion | Comp Cam Custom Grind | Mast Heads | Comp Cam Push Rods | LS7 Timing Chain | 180 Thermostat | Ported Intake | Ported TB | SLP UDP | K & N CAI | Custom 3800 Stall Converter | Aluminum 1 Piece Driveshaft | Kooks 1 7/8" LTH | High Flow Cats | ARH 3" Exhaust | ARH Mufflers | Eibach Lowering Springs | BMR Floor Brace Subframe Connectors with Tunnel Brace | BMR Moly Lower Rear Control Arms | Oracle LED Halo Kit
Cyber10 is offline   Reply With Quote
