Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 03-07-2013, 07:53 PM   #1
1979camaro
Drives: 1979 camaro
Question Body work "doors"
New to forum. Looking to see if anyone has info on a problem I have run into. After stripping the doors down to metal I noticed a dip in both doors. It is in the center of the lower portion of the doors about 3 inches up from the bottom of the door and is about 6" x 8". This area also seen to have alot more flex than rest of the door. I also notice there is no frame work in this area on the inside of the door. Is this a factory issue or a correctable problem?
1979camaro is offline   Reply With Quote
