09-05-2022, 07:03 AM | #1 |
Drives: 23 2SS 1LE Join Date: Feb 2019
Touch screen not working
2019 3LT - I have already done the F16 fuse pull with no luck. I have this issue every now and then where the touch screen just stops functioning. The screen stays on, it's lit up and the songs will update, etc... but the touch function doesn't work whatsoever, and the buttons under the radio don't work either.
Volume can only be adjusted from the steering wheel, and the screen display can be changed from there as well. Any help would be appreciated!
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 Black on black 2019 3LT RS Camaro. 1100: 3/7/19 | 4200: 4/15/19 3100: 3/15/19 | 4800: 4/23/19 3400: 3/22/19 | 5000: 4/25/19 Built: 4/8/19 | Home: 4/26/19 Last edited by RideWithDanger; 09-05-2022 at 07:58 AM. |
10-26-2022, 09:08 AM | #2 |
Junkie
Something similar going on with mine- any update?
"Letty" Murdered out 2013 Camaro 1LE. (Old car SIM 2010 2SS/RS)
10-26-2022, 12:48 PM | #3 |
Drives: 2020 Callaway Camaro SC630 Join Date: Feb 2020
Try number 55 as well.
As one person tried, they pulled and reinserted all fuses in the rear box and that fixed the problem.
2020 Callaway Camaro SC630 - MN6 1SS Satin Steel Gray
2019 Callaway Corvette SC757 - MN7 1LZ Elkhart Lake Blue |
