08-13-2011, 01:29 PM | #1 |
5th Gen
Drives: 10 SS Join Date: Jul 2010
1999 Ford Escort died twice, wont start
I've looked it up and we see the valves are moving so its not the timing belt. A friend told me to disconnect the gas line from the engine for half an hour and then plug it back in and pump gas three or so times, then to start the engine. The battery isn't in the equation but we are also charging it to take it out of question for sure. Any clues what it is? We even can see the timing belt moving a little its a "Split Induction 2000" manual 5 speed.
08-13-2011, 01:34 PM | #2 |
Back on the dino-juice
Drives: '10 LS + a few more Join Date: May 2010
Are you getting fuel? Spark?
I wake up in the morning and I piss excellence.
-Ricky Bobby America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936 |
08-13-2011, 01:34 PM | #3 | |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
The Bird is the word! |
08-13-2011, 01:47 PM | #4 |
5th Gen
those are on the list to check later today
Thanks, well check those today |
08-13-2011, 02:18 PM | #5 |
Also you may want to check the fuel pump and fuel filter. did it just die or sputter and die?
Pumping the gas before starting won't do anything in a fuel injected engine.
08-13-2011, 04:39 PM | #6 |
5th Gen
I'm not sure its my fathers car, but we already replaced the fuel pump and the fuel filter.
08-13-2011, 06:39 PM | #7 | |
I got this info from E-How Troubleshooting Ford Escort Fuel Cut-Off Problems Print this article The Ford Escort, like many Ford cars and light trucks, comes equipped with a fuel-pump shut off. This fuel-pump shut off, called an inertia switch, prevents fuel from being pumped to the engine in the event of an accident like a rear end collision or rollover. A defective inertia switch will cause the fuel pump to shut off and the engine to not start. Circuit Function This switch activates when a metal ball that is magnetically held against two contacts is knocked loose by the impact. Reset the switch by pushing the reset button located in the trunk or under the right side of the dash. Power to the circuit is supplied to the switch by the fuel pump relay when the relay is energized by the on-board computer. The ground circuit is through the switch first, then through the fuel pump. Testing the Switch To test the switch and determine if it's a bad switch and not a bad fuel pump, push the reset button. These switches can be tripped by a sharp blow to the trunk lid---sometimes all that is needed is a reset If the vehicle still fails to start, unplug the wiring connector at the switch and test for power on one side of the connector and ground on the other side. This is the normal state of the circuit. Power comes from the fuel-pump relay, and ground is found through the fuel pump. If there is no power, but there is ground, the fuel pump relay or fuel pump fuse could be the defective part. No ground indicates a wiring problem to the fuel pump or a defective fuel pump. If you have power and ground, install a jumper wire to bypass the switch. If the engine will start and run normally, then the switch can be called defective. If the engine still does not start, check for power at the fuel pump. If there is power and ground at the fuel pump, then the fuel pump can be called defective.
08-13-2011, 09:06 PM | #8 |
Why are you driving an old Escort?
08-13-2011, 09:42 PM | #9 |
08-13-2011, 09:42 PM | #10 |
Similar Threads | ||||
Help Me Pick An Economy Car | Marosolid | Off-topic Discussions | 75 | 07-11-2009 06:41 AM |
Ford Interceptor | Urthman | General Automotive + Other Cars Discussion | 18 | 07-24-2007 01:48 PM |
Ford to rebrand Five Hundred with Taurus name | KILLER74Z28 | General Automotive + Other Cars Discussion | 9 | 02-08-2007 03:02 PM |
Interesting read on American cars and trucks...... | fbodfather | General Automotive + Other Cars Discussion | 8 | 12-22-2006 08:47 PM |
Financial Problems for Ford??? | TAG UR IT | General Automotive + Other Cars Discussion | 14 | 10-29-2006 06:17 PM |
