05-30-2014, 02:52 PM | #1 |
Chief Many Camaros
Drives: A paid off Camaro!!! Join Date: Mar 2009
Need help finding new 3" catback.
Hoping some out there could chime in on the best 3'' cat-back to run that has the least amount of drone at highway speeds 75-80mph.
I currently have the CNT racing 3'' cat-back and recently added Kooks LTs and high flow cats, although I love the sound under all other driving conditions, the drone that is present since the header install at 75-85mph in 6th is almost unbearable for any distance (50 miles+). Anybody have any recommendations, would like to stick with a 3'' system with an x-pipe. Thanks.
504hp/478tq Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac |
05-30-2014, 03:03 PM | #2 |
Drives: 2010 ABM SS Join Date: Feb 2011
Corsa
Sold 2010 ABM 2SS RS. Kooks, Corsa CB
05-30-2014, 03:18 PM | #3 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Have you though of adding j pipes to your existing catback?
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
05-30-2014, 03:23 PM | #4 |
Chief Many Camaros
I've thought about the J-pipes, and depending on price that may be the way to go, I was just hoping to get opinions on drone-less exhaust first to keep the underside of the car as clutter free as possible. Thanks though.
05-30-2014, 03:23 PM | #5 |
Drives: 2023 2SS Convertible Join Date: May 2009
The factory Z28 system is 2.75" and it is NPP, so you could switch off the drone when you wanted. Just a suggestion - pretty sure it isn't on the "block" list.
-Geoff
'12 2SS RS Convertible - Traded in.
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold! '23 2SS Convertible -Same as above except orange. |
05-30-2014, 03:28 PM | #6 |
Chief Many Camaros
Now that's an idea, I wonder if the tips are bolted on or welded, I think I would like to stick with the single exhaust tip.
06-01-2014, 11:53 AM | #7 |
Drives: Cyber Grey 2010 2SS RS Join Date: May 2012
It's funny that, I'm running pretty much the same set up OBX long tubes (kooks clones) and the same car back and my drone is lower in speed by about 10 mph.
2010 2SS/RS
-Headers, catback, Holley Mid-rise and a 150 shot- |
06-01-2014, 11:55 AM | #8 |
Also curious about cost for JULY pipes.
2010 2SS/RS
06-01-2014, 11:58 AM | #9 |
Drives: 2012 2SS LS3 Join Date: Jun 2012
People say that the Stainless Works Retro Chambered Catback has no drone. Never heard it in person, though.
06-01-2014, 02:22 PM | #10 |
Scott's45
Drives: 2012 2SS 45th Anniversary Join Date: Mar 2012
It doesn't have any drone.....until you add LT headers. Now it drones, but not as annoying as I thought it would be.
2012 2SS 45th Anniversary, Hurst short throw shifter, Stainless Power LT headers, high flow cats, SW Retro Chambered 3" cat back, CAI, Heritage grill, tinted windows, red/silver hash stripes, AAC LED sidemarkers, blacked out turn signals/tail lights, splash guards. 402RWHP
06-01-2014, 08:01 PM | #11 |
PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
Downsized from a droning MBRP 3" X system (LS3), then resonated H flavor midsection (L99) to a Solo Mach XL J-pipe 2.5". No drone and no loss of real world performance. 60-100 in third still logged 3.6 sec in HPTuners scanner.
Stepped headers and 10+ psi boost. If I lost any power it isn't noticeable in the logged times and I can stand to drive it on the highway again. Some say it will choke off boosted applications with the 2.5" but I can't see it @ ~650 whp. Just keeps the exhaust velocity up.
06-02-2014, 10:32 PM | #12 |
Drives: Supercharged 2013 AGM 2SS/RS Join Date: Oct 2013
I recently added the 3" Magnaflow, though LT headers ain't legal here / I don't have any. That said, I haven't noticed much drone and can easily have phone calls when cruising on the freeway. Overall I wouldn't describe the Magnaflow system as particularly loud inside or outside.
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports. 1967 Bolero Red 396 SS/RS Convertible |
06-03-2014, 10:08 AM | #13 | |
Chief Many Camaros
Thanks for all the replies, I still haven't settled on a system yet, but from the sounds of it I may have to step down to a 2.5'' exhaust.
06-03-2014, 11:44 AM | #14 |
Tune-able Solo 3" catback, or at least the J's.
