View Poll Results: ECS or Used Procharger F1-R w/cog drive? | |||
ECS Tuner Kit - NEW | 10 | 58.82% | |
Procharger F1-R w/cog drive - USED | 7 | 41.18% | |
Voters: 17. You may not vote on this poll |
Thread Tools |
11-12-2014, 05:41 PM | #1 |
Chief Many Camaros
Drives: A paid off Camaro!!! Join Date: Mar 2009
ECS Vs. PROCHARGER F1-R Cog, Need Help Quick!!!
Well guys, I was set on a new ECS kit, but have come across a used Procharger F1-R with cog tuner kit that in the end would be about equal on price.
I plan on being on the stock LS3 bottom end (5-6 years) for quite a while and plan on sitting about 600-650 hp and will be running a meth-injection setup for added safety. Edit, I failed to mention, the procharger would end up being ran with 850cc injectors and a dual fuel pump setup in the figured price vs BAP and included injectors on the ECS. Which would you guys go with and why? I really need to decide tonight since this deal probably won't last long. Thanks
504hp/478tq Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac Last edited by K1SSRSS; 11-12-2014 at 07:31 PM. |
11-12-2014, 05:51 PM | #2 | |
Slowhawk Built
Drives: 2010 Supercharged SS Join Date: Apr 2014
If the prices are equal I'd get the brand new kit.
9.21 @ 149 Slowhawk Performance
11-12-2014, 06:04 PM | #3 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
I would not suggest a cog on a street car, especially a stick
11-12-2014, 06:32 PM | #4 |
F1r is a nice setup and unless you do ysi support more power.
Nick
Corvette Z06 -1200ish rwhp |
11-12-2014, 07:10 PM | #5 |
Drives: 2013 SS Join Date: May 2013
I would do the ECS kit if your only looking for 650
11-12-2014, 07:12 PM | #6 | |
Chief Many Camaros
I'm not sure what might be involved to change it back over to a 10 or 12 rib setup, but can you shed some light on why a cog drive setup is not ideal on a m6 street car? Thanks in advance for sharing your knowledge.
504hp/478tq Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac |
11-13-2014, 09:36 PM | #7 |
Drives: Silver 2SS, 68 Firebird 400,70 vett Join Date: Jul 2009
Send moiy1983 a pm everything they are saying has some truth to it. He will share his experience with you.
11-13-2014, 10:00 PM | #8 |
I have 12psi from a Paxton with 850cc FICs fed by LPE twins. No issues.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X Last edited by Bo White; 11-14-2014 at 06:39 AM. |
11-13-2014, 11:22 PM | #9 |
Chief Many Camaros
Thanks for the leads and info.
