Old 05-11-2017, 02:51 PM   #1
CDN SS
Steve from Canada.
CDN SS's Avatar
Drives: 2010 SW SS/RS with Inferno package.
I keep failing my E test.
2010 SS, CAI intake, Borla Shorty headers, Solo free flow cats, muffler delete. The car is failing on EVAP and O2 readings.
Any suggestions?
CDN SS is offline   Reply With Quote
Old 05-11-2017, 03:31 PM   #2
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
dynoSteve at RDP ASAP or put all your stock stuff back on...good luck...erm...your not failing a VISUAL test are you?
Old 05-11-2017, 05:20 PM   #3
SRTKILLER
SRTKILLER's Avatar
Drives: 2009 Cadillac CTS-V
How many times have you failed? I had my SS down for the winter when I hooked the battery up I took it the next day for a test and it wasn't ready. All the monitors were not ready, so I drove it for a couple more days failed again! Now they had to do a two speed idle test, which means put the sniffer in the tailpipe instead of obd11. With my stroker motor I knew I would fail again which I did. I ended up getting my buddy Eric who makes the green cats for kooks to put two brand new ones on and bam it passed! What I'm getting at is you do not want to do a two speed idle test with a modded car it can be a big headache.
SRTKILLER is offline   Reply With Quote
Old 05-11-2017, 07:58 PM   #4
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
If you are getting Not Ready errors you need to drive the Camaro more.
All the sensors reset if you disconnect the battery, even for a few minutes.
I took mine on the highway for ~40 minutes and that took care of that.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 05-11-2017, 08:16 PM   #5
SRTKILLER
SRTKILLER's Avatar
You are right there, but sometimes it can take more than just one 40min drive. But that's exactly what I was thinking the monitors are not ready.
Old 05-11-2017, 09:06 PM   #6
CDN SS
Steve from Canada.
CDN SS's Avatar
No tune, battery was disconnected over the winter. I've only driven it about 60 KMs so far. Failed twice.
Old 05-11-2017, 09:50 PM   #7
CamaroFred
CamaroFred's Avatar
I did some hours around home and the Evap became ready but the O2s needed the highway run.
2011 1SS/RS LS3 CGM
Old 05-11-2017, 11:53 PM   #8
pump905
pump905's Avatar
Drives: 2011 2ss/rs black with white rally
U have to tune for the headers and high flo cats
pump905 is offline   Reply With Quote
Old 05-12-2017, 06:32 AM   #9
SRTKILLER
SRTKILLER's Avatar
Did it say you have to do a two speed idle test? Sounds like all the monitors are not ready. Do you or a friend have a scanner to tell if the monitors are ready? Google engine monitors not ready and it will show you how to cycle your car properly.
Old 05-12-2017, 01:51 PM   #10
Outlaw77
Outlaw77's Avatar
Drives: 2018 Charger SRT 392 F8 Green
you have to get tuned. I just tested my camaro with NO cats and I passed.
Outlaw77 is offline   Reply With Quote
Old 05-12-2017, 03:39 PM   #11
SRTKILLER
SRTKILLER's Avatar
The problem now is when you fail twice they will do a 2 speed idle test (sniffer in the tail pipe and revved up) It happened to me about a year ago. It cost me two brand new cats to pass.
Old 05-12-2017, 09:58 PM   #12
CDN SS
Steve from Canada.
CDN SS's Avatar
I was told you don't need a tune for shorty headers.
I have never done a real E test, service adviser plugs a machine into the ODB.
Old 05-12-2017, 11:03 PM   #13
prod
prod's Avatar
Drives: HHR
Did he tell you it failed, or that it wasnt ready? Anyone with OBD2 dongle and app can find that out too.
60km sounds like it may not have been run through enough, it can take days or a prescribed cycle.
prod is offline   Reply With Quote
Old 05-13-2017, 09:20 PM   #14
CDN SS
Steve from Canada.
CDN SS's Avatar
Service adviser hooked up an ODB reader and it showed 2 red X's, I've never actually done the test. I'm planning a full day of driving tomorrow and taking it back in on Monday.
