Old 02-16-2011, 09:57 AM   #1
SSambumbia
Drives: 2ss/rs black/black
Pedders xa's coilovers(track II kit) and Pfadt camber plates
Is anyone using this combination? If so what are your thoughts. Any noise from the camber plates? Car is mostly DD and might see some track and drag a couple times a year.
Those of you that live in crappy roads like here in PR, what height are your xa's set at.
SSambumbia is offline   Reply With Quote
Old 02-16-2011, 10:04 AM   #2
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
We have a couple of people running Xas and Supoercars with the camber plates. Some were w bit upset when I told them there was suffcient adjustment roos without plates to get to -2.5 camber. Our alghnment bolt kit provides castor adjustment and the extends the rear camber adjustment range by 1 degree. Unless you are doing hardcore HPDE or autocross you will not need any additional front camber adjustment range.
On rough roads (we have them up here too) 5 to 8 off full soft front and 7 to 12 off full soft rear.
Old 02-16-2011, 10:41 AM   #3
SSambumbia
Hmmm. Interesting. I have the car at the shop with the track II ready for install and I had bought the pfadt camber plates and I am undecided if I should put them in or not. I don't want to end up ruining dd ride/noise quality because of them.
I meant the distance from the bottom of the rim to fender, not the adjustment of soft/hard.
Old 02-16-2011, 10:52 AM   #4
JusticePete
Ebay would be my answer
Height is easy. Set it down 40mm front and 45mm rear!
Old 02-16-2011, 11:02 AM   #5
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Hi SSambumbia,
We have had a handful of people in your situation, wanting to get fast, easy camber/caster adjustment without any modifying to your frame, while using coilovers besides Pfadt coilovers. I have heard nothing but good things from these customers.
These camber plates make no noise so I would not be worried about any added NVH from these plates themselves.
Old 02-16-2011, 11:07 AM   #6
SSambumbia
Is that measurement from the top of the tire to the fender?
Thanks.
Old 02-16-2011, 11:12 AM   #7
600hp-lpe
Drives: 2010
Both MWS444 and I run the PFADT camber plates with the full pedders track kit.
It works fine, with no noise. It's the best way to get another 1 deg. neg camber if you need it. you can get -1.5 deg without the camber plates.
I run -2.5 neg camber on my car up front all the time... Not recommended for the street unless you have an unlimited tire budget. My car sees more race track time than street use.... and I have 3 sets of wheels, so I don't have a problem with tire wear.
600hp-lpe is offline   Reply With Quote
Old 02-16-2011, 11:18 AM   #8
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
I have them on my car as will, it is my DD and have no problems with the ride, And i run 8mm of space from top of tire and fender.
Old 02-16-2011, 11:31 AM   #9
JusticePete
Thanks.
Measure from the lower edge of the wheel rim, up through the wheel center to the painted edge of the fender.
Old 02-16-2011, 12:18 PM   #10
SSambumbia
Measure from the lower edge of the wheel rim, up through the wheel center to the painted edge of the fender.[/QUOTE]
Unless there is a typo I can't figure out how I can get 40mm(forty) from the bottom of the rim to edge of fender. That is roughly 1.5"
Old 02-16-2011, 12:22 PM   #11
SSambumbia
Sorry. Re-read your post, it says set it down 40mm, not set it at 40mm. So I take stock measurement and deduct 40front and 45 back.
Old 02-16-2011, 12:23 PM   #12
JusticePete
Unless there is a typo I can't figure out how I can get 40mm(forty) from the bottom of the rim to edge of fender. That is roughly 1.5"[/QUOTE]
Sorry about that. With 20" wheels the SS has an averaged ride height of 690mm front and 700mm rear from the factory. What I am suggesting is that you lower the front to 650mm and the rear to 655mm. If you haven't alreaddy started the installaion, measure your OE heights and then just subract 40mm front the front and 45mm fron the rear.
OK?
Old 02-16-2011, 12:23 PM   #13
JusticePete
Old 02-16-2011, 03:15 PM   #14
600hp-lpe
Drives: 2010
I was laughing really hard at that one... ROFL!!!!!
yup... would be hard dropping the car that much! LOL
Pfadt Introduces New Front Camber Plate Kit. Available NOW! PfadtRacing Suspension / Brakes / Chassis 43 02-07-2013 12:40 PM
Pfadt Race Engineering's newest distributor is... Apex Motorsports Suspension / Chassis / Brakes 6 06-12-2011 10:53 AM
New PFADT Sway Bar End Link Kit ULTRAZLS1 Suspension / Chassis / Brakes 5 02-11-2011 09:50 PM
Finally finished picking my Suspension mws444 Suspension / Brakes / Chassis 38 06-04-2010 01:02 AM
