07-08-2012, 10:04 AM | #1 |
Sellin Chevy's since '06
LSA vs LS9 Camshaft
Are there gains to be had with an LS9 cam? The only specs I could find were
.480" / .480", 198 / 216 @ .050" for the LSA 211/230 @.050 valve lift and .558/.552 for the LS9 Couldn't really find more info than that on the LSA cam. Because when you google LSA , it always tries to pop up "lobe separation angle" I cannot find the "lobe separation angle" spec on the LSA cam. Granted you will ALWAYS make more power with a custom grind cam....but for those that wanna go inexpensive the LS9 camshaft is around $125 and you don't necessarily have to go with a dual spring upgrade since it's a factory cam.
'19 Z06-7Speed and lowered on stock bolts
'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0 SOLD! '18 ZL1 Mosiac Blk SOLD!'16 SS Sedan-Forgestars/ARH/rotofab TRADED!2014 SS Sedan SOLD! 2013 Blue Ray1SS/1LE 1of20. TRADED! 2012 White 1SS/RS |
07-08-2012, 10:11 AM | #2 |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
LS-9 cam is a 25 HP gain for a normally aspirated LS-3. You will also need the 3-bolt cam timing gear. No other changes required. I put one in during a supercharger install and I am happy with it. Smooth idle and no tune changes required. A custom tune is allways good to have but the powertrain warranty goes away so decide for yourself if that makes a difference to you or not.
-Mark. |
07-08-2012, 11:10 AM | #3 |
I knew that for the LS3, but I wanted to know what the gains were in an actual LSA engine vs the factory LSA cam. It appears to be a bit more aggressive of a cam and already has blower specs.
07-08-2012, 11:29 AM | #4 |
Drives: 2012 ZL1 #165 Join Date: Apr 2009
I would like to know this too. I'm sure someone over in the cts-v forum has done this...
07-08-2012, 11:30 AM | #5 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
You might want to check out a CTS-V forum, since I'm sure some of the members have made this swap. There's just not enough ZL1 owners who've done this level of mods yet and most would choose a larger cam. I believe Ligenfelter sells this can as one of his upgrades.
07-08-2012, 11:47 AM | #6 |
Drives: 2012 ZL1, 2009 CTS-V Join Date: Jun 2011
You will pick up about 35 RWHP with the LS9 cam over the LSA cam.
07-08-2012, 11:56 AM | #7 | |||
Still reading... http://www.cadillacforums.com/forums...cam-way-5.html
07-08-2012, 12:02 PM | #8 |
Drives: fanboys and ass kissers crazy. Join Date: May 2008
Has anyone here done nothing but an LS9 cam swap on an LS3? Cam only and nothing else. Looking for a review. Thx
07-08-2012, 12:07 PM | #9 |
Will a swap on an ls3 allow any conclusions for the lsa?
07-08-2012, 12:08 PM | #10 |
Drives: 2011 imperial blue SS, black 92 RS Join Date: Apr 2011
What valve springs would you use with the ls9 cam? This sounds like a good choice for a daily driver and someone who doesn't want a stall. Hmmmm
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :( 2017 Silverado 5.3 all stock 2004 5.7 GTO 78mm turbo |
07-08-2012, 12:19 PM | #11 |
Looks like some in this thread stuck with stock whereas others upgraded... I guess its added insurance!
07-08-2012, 12:22 PM | #12 |
07-08-2012, 12:43 PM | #13 |
Drives: 2010 Duramax; 2012 CTS-V Coupe Join Date: Apr 2012
07-08-2012, 01:16 PM | #14 |
Did you read the specs listed at the top? The LS9 cam has quite a bit more lift and duration than the LSA cam. If someone wanted a stealth cam this would be it.
