#Camaro6
Go Back   CAMARO6 > Specific Packages / Variants > 6th gen Camaro Convertible
AWE Tuning
Old 06-25-2021, 06:25 PM   #1
Bob54
Drives: 2016 1LT RS Convertible
Replaced the battery, Right move?
I have the V6 and a 2016 convertible. Yesterday it seemed like a couple of times I started the car there was an ever so slight hesitation on the crank speed. The battery is at least 4 1/2 years old. I used the dealer and the cost out the door was $400. I think I did the right thing given that the battery is in the trunk and is a pita to get at. Just wondering what the group thinks. My wife slightly questioned the decision but she appreciates that we don't want to have to worry about it.
Bob54 is offline   Reply With Quote
Old 06-26-2021, 08:13 AM   #2
ember1205
Hot Camaro
ember1205's Avatar
Drives: '20 2SS Convertible 6MT
My truck was just about five full years old when the battery just puked. Very little warning prior to that except a couple of times that it sort of "slow cranked." Physically replacing the battery isn't necessarily difficult, just a little convoluted because it's in cramped quarters. If you're happy with the decision and the cost, and the issue you were having doesn't return, then it sounds like a win to me.
ember1205 is offline   Reply With Quote
Old 06-26-2021, 10:44 AM   #3
Plasar
Drives: 2017 ZL1 Vert M6
Thumbs up
My 1999 BMW M3 convertible needed a battery swap at the 5 year mark. Completely normal. The internet seems to say "3 to 5 years".
Consumer Reports - Car Battery Buying Guide
On the $400 for the battery and swap, do you know how much the battery "part" was an how much the labor was?
In any case, I would suggest you find a good local independent auto mechanic who will give you great service, do your normal scheduled maintenance and special requests, and beat the dealer's price. I checked Yelp, found Alvin's Auto Center in San Jose, and they have done fantastic work for me: installed mods like skip shift/1 touch top down/Gen 2 charger pad, and done services like oil/brake fluid/coolant. They are so diligent that they even notified me that my coolant color changed from pink (factory DexCool) to orange (refill DexCool) and they confirmed with their Chevy service contact that this is normal (check the web for conspiracy theories).
Alvin's Auto Center San Jose
Plasar is offline   Reply With Quote
Old 06-26-2021, 06:23 PM   #4
ember1205
Hot Camaro
ember1205's Avatar
Sadly, the batteries for these cars generally run at least $300.
Old 06-27-2021, 10:59 AM   #5
Plasar
Thx Ember. I'm a huge Consumer Reports fan. If the Camaro battery is a Type 48 (per GM Parts Center), a snippet of prices shows that some of the batteries approach $300, but some well/top rated ones can be gotten for $200 or less.
GM Parts Center - Home 2017 Chevrolet Camaro 88864541
Old 06-27-2021, 06:00 PM   #6
Bob54
Thank you for you comments. The battery part was $260. Amazon had it for $190. Being close enough to walk to the dealer. Priceless ( well close).
Old 06-28-2021, 09:24 PM   #7
GroundhogSS
GroundhogSS's Avatar
Drives: '17 2SS convertible'20 Yukon Denali
Be sure you get the AGM version of the battery.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers
Delivered: 08/15/2016
#TeamBeckyD
GroundhogSS is offline   Reply With Quote
Old 06-29-2021, 04:35 AM   #8
He11bent
He11bent's Avatar
Drives: 2019 2SS Convertible Camaro
Just FYI, there are threads on here about slow crank issues. The resolution is changing the negative battery cable and ensuring the ground at the frame is clean of paint, etc.
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness
K&N AirCharger Cold Air Intake
Sound Tube Delete
He11bent is offline   Reply With Quote
Old 06-29-2021, 10:09 AM   #9
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
$400 isn't bad.
I got one of these and installed myself. A bit easier to do the install in the vert since the trunk trim easier to temporarily fold out of the way.
https://shop.advanceautoparts.com/p/...agm/10210829-P
Gunkk is offline   Reply With Quote
Old 09-21-2023, 09:07 PM   #10
cengell
Drives: 2017 2LT Garnet Red
2017 RS Convertible Replaced battery myself.
I know this is an older post, but maybe this will help someone... So I have a 2017 RS Convertible and 2 days ago went to start it and all I heard was a pre start click and that's it, it's never not started since I got it!
So I was thinking it's the AGM battery and it's an AC Delco battery, so I found 1 48 at Batteries Plus $300 ish and then I looked at Amazon same basic all having a 3 year warranty and then just checked Walmart and they have same spec "EverStart Platinum AGM Battery, Group H6 (12Volt/ 760CCA)" $179 and coupon "WOWFRESH" save $10 so $169 + tax, and saw no core charge, but read later that it's built in. So $183.00 got it yesterday and the sticker shows 8/23 made date so not old stock. So today put it in and fits great and the vent port same as the AC Delco and put the bracket in and cleaned off the Neg terminal as looked needed cleaning with fine sandpaper.
So for $183 with tax, all I had to do is fully charge it took 4 hours at 10 amp charger and worked...So far go deal?
https://www.walmart.com/ip/EverStart...0CCA/944775111
Christopher
cengell is offline   Reply With Quote
Old 09-29-2023, 02:03 PM   #11
GroundhogSS
There is a top position sensor behind and above the battery on the top mechanism. Be careful that you don't knock the connection off when you're wrestling the battery in. It will report that the top action is not complete.
I found out the hard way.
Richard
#TeamBeckyD
Old 09-30-2023, 01:05 PM   #12
cengell
Thanks for that info, I don't have that guard so I don't bring down the top as on the drivers side right where that sliding panel I think is broke and won't retrack so I I just leave the top up as I am hoping a better info on how to fix it myself as the GM ext warranty does not cover that. Of course they know what breaks so not covered.
Thank you posting that tip!
Christopher
