12-24-2015, 04:36 PM | #1 |
Sarcasm loading --------
Just installed Michellin PSS 285 / 315
A lot more grip at lower temperature.
The rears rub a little bit when I go over an off camber curb. These were expensive in comparison to the goodyears, they cost me $1700 after tax shipping and install.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD Last edited by nighttowl; 12-28-2015 at 07:19 PM. |
12-28-2015, 07:19 PM | #2 |
After a few days of driving, I am noticing that the rears rub over bumps in the road as well as off camber curbs.
The steering is also less responsive than with the factory Goodyear F1's. A lot more grip, but feel less firm; tire pressure is at 36.
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
12-29-2015, 01:12 AM | #3 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Did you get the K1's or the K2's?
One (K2) has narrower tread width (11") but greater tread depth (10/32).while the other (K1) has a wider tread width (11.5") but shallower tread depth (7/32). I have the same setup on a 2013 ZL1 convertible with the K2's I mine don't rub at all. |
12-29-2015, 03:32 PM | #4 |
not sure.
The tires are rubbing on the plastic fender flare, not on the body. The rears for a Ferrari was all that was available, not sure which one that is. They said there were only 4 sets nation wide available, now there are 3. I talked with 2 tire dealers, supposedly Michelin is behind on deliveries for all of the super sport tires.
01-01-2016, 06:13 PM | #5 |
Drives: 2015 ZL1 Bright Yellow Join Date: Apr 2014
The Ferrari rear is K2 for MPSS
01-02-2016, 04:27 AM | #6 |
Native Floridian
Drives: 2014 - ZL1 / 2003 - Corvette Join Date: Oct 2013
I'm running Michelin PSS 295's on the front and 315's on the rear with no rubbing issues.
01-04-2016, 01:46 PM | #7 |
Drives: 2014 CRT ZL1 Join Date: Jun 2013
I had occasional rubbing on the upper corners of the rear bumper fascia.
I smoothed the inside edges, now all better. The front corners also rubbed with the extra wide 295s. Better with the regular 295s, but still sometimes a bit of rub on the driver side.
ZL1 Camaro - Worlds Largest Sports Car
Road King - Not Garage Queen |
01-04-2016, 07:38 PM | #8 |
It rubs only in the back, on both sides.
I just have to take it easy over bumps. I don't regret the buy, but I'm not sure if I would bur again, The steering response is much slower. Maybe I could pick up a spare set of wheels later this year to have the Goodyear's as summer tires. They had good grip when its more than 80 degrees out.
01-19-2016, 03:52 AM | #9 | |
Drives: 2017 ZL1 Garnet Red Join Date: Feb 2015
01-19-2016, 03:54 AM | #10 | |
I also have a set of 5-Spokes with the factory rubber (5/32 left) and includes new air pressure sensors. Thanks, Sam. |
Thread Tools | |
