Old 01-04-2014, 04:18 PM   #1
TheBandit18
TheBandit18's Avatar
Drives: 2011 Camaro 2ss M6
way low gas mileage
I just bought a 2010 Camaro 2ss and I was curious about my mileage I only drive to work and back which is like 3 blocks away. My mileage is not even 7MPG!!!!!!! could there be any issues that make it this low?
I hardly ever get on it since I don't drive very far. and only mods are roto-fab intake.
I know its a sports car and you shouldn't worry about mileage but my last one was getting around 9mpg with a cam
TheBandit18 is offline   Reply With Quote
Old 01-04-2014, 04:20 PM   #2
revived
Vrrrm.
revived's Avatar
Drives: 2011 2SS/RS LS3
Not normal at all I average 16-19 depending on how much highway driving I do
revived is offline   Reply With Quote
Old 01-04-2014, 04:57 PM   #3
FaytalsCamaro
Distributor of Liquor
FaytalsCamaro's Avatar
Drives: My Wife Crazy
14.8 here last i checked and i drive it how it is meant to be driven...like it was stolen...lol
FaytalsCamaro is offline   Reply With Quote
Old 01-04-2014, 05:19 PM   #4
He11bent
He11bent's Avatar
Drives: 2019 2SS Convertible Camaro
Thats really low. I will average 14 in heavy city traffic. Clean the air filter and a fuse pull. See if that helps you.
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness
K&N AirCharger Cold Air Intake
Sound Tube Delete
He11bent is offline   Reply With Quote
Old 01-04-2014, 05:23 PM   #5
wayne watson
wayne watson's Avatar
Drives: 2014 camaro ss ,1967 chevelle ss,
If your drive is really that short what is it going to get a average of. Not even at operating temp yet. Mine to work which is 30 miles away gets 17.5-18 I think you should try 20-30 mile trip and see
wayne watson is offline   Reply With Quote
Old 01-04-2014, 05:27 PM   #6
1COR.1:18
Whosoever Will
1COR.1:18's Avatar
Drives: 2010 1LT Victory Red
3 blocks? You car is not even warming up.
Take it out on the Expressway for about 15 mins then set the cruise to 70 and
reset/recheck your mpg.
1COR.1:18 is offline   Reply With Quote
Old 01-04-2014, 05:29 PM   #7
TheBandit18
I have taken it to the city which us a good 45 minute dtive going 70mph I get around 19mpg.
Old 01-04-2014, 05:36 PM   #8
Revster
Drives: 2015 ZL1
If I was 3 blocks from work I would just walk.
Revster is offline   Reply With Quote
Old 01-04-2014, 05:42 PM   #9
wayne watson
Well that's your average. When a injected engine is. Cold the pcm keeps it rich so it won't stall like carbureted engines will until it warms up.
Old 01-04-2014, 06:16 PM   #10
EMB135Driver
Jedi Master
EMB135Driver's Avatar
Drives: Boeing 757/767+2010 IBM 2SS
I think if I lived 3 blocks from work I'd leave my car at home and walk.....less chance of damage/accidents and better for the engine to fully warm up instead of really short trips.
EMB135Driver is offline   Reply With Quote
Old 01-04-2014, 06:21 PM   #11
CamaroJim56
Obsessed
CamaroJim56's Avatar
Drives: 2016 Hyper Blue 2SS RS
Like the others have said, too short of a drive.
Zero it out, and take it on a real trip so it can be fully warmed up.
2016 Hyper Blue 2SS
CamaroJim56 is offline   Reply With Quote
Old 01-04-2014, 06:30 PM   #12
TheBandit18
Ok thanks! the reason why I don't just walk is becuz I sometimes have to drive my vehicle for work purposes so it would be pointless to walk then get there and find out I have to go back and get my car
Old 01-04-2014, 06:36 PM   #13
banter
banter's Avatar
Drives: 2016 Camaro 2SS M6 Black
It's the short trips that are doing it. As someone previously stated, the engine runs rich when the block is cold to prevent stalling. My cobalt got 23mpg when I'd just drive to and from work when I worked 2.5 miles from my house. When I started working 14 miles from my house it jumped up to 35mpg.
banter is offline   Reply With Quote
Old 01-04-2014, 10:28 PM   #14
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
Your short 3 block drive is probably the worst thing you can do to a car, especially during cold/winter months. None of the fluids have time to warm up, which means potential contaminants/moisture can stay in your engine/transmission/etc.
Although your 7 MPG does seem low, it doesn't really surprise me. When you first start your car in the morning, your car's computer is in "open loop". Without going into too much detail, it basically means your car is running rich. Once certain parameters are met (predetermined warm coolant temperature, etc.), the computer goes into "closed loop". This leans out your fuel mixture, which means better driving dynamics and better mileage. I'm guessing your car barely gets out of 'open loop' during your drive.
Have you ever considered walking or maybe taking the LONG way to work?
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
