#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Cosmetic modifications (exterior and interior)
Old 07-13-2018, 08:38 PM   #1
Lord M
Drives: 18 6.2
Talking How To: Remove Chrome Center Vent/Control Rings
I couldn't find anything on here on here on how to remove the chrome center vent rings so I figured I would just go at it and probably be the first. It was amazingly simple,I just took a flat head screwdriver placed it in between the ring and plastic behind it and pried up and did that around the ring they come off very easy. To put them back in just place them over where they go slightly spin and push in until they click into place. I painted them, they came out pretty cool.
Lord M is offline   Reply With Quote
Old 07-13-2018, 09:37 PM   #2
Move_Over
Drives: ISO ss 1le
I wouldn't recommend going at the plastic with a metal screwdriver. May want to use a trim removal tool, or throw some painters tape or a cloth over the tip of the screwdriver. This plastic can get mucked up real fast.
Otherwise, thanks for the how to!
Move_Over is offline   Reply With Quote
Old 07-15-2018, 08:00 PM   #3
Haole
2017 SS
Haole's Avatar
Drives: 2017 Summit White 2SS
Any idea about removing the other 2 vents?
Haole is offline   Reply With Quote
Old 07-15-2018, 11:40 PM   #4
squish72
Drives: 2016 2SS 8AT
Can you remove the vent once that is off? I'd love to replace one of mine but don't know how much work it would be to do so.
squish72 is offline   Reply With Quote
Old 07-16-2018, 12:02 AM   #5
Haole
2017 SS
Haole's Avatar
I took the a/c vents off plasti dipped white and put back on. I had the shifter trim plasti dipped as well but need to re do.
Old 07-19-2018, 08:19 PM   #6
RobertAvitia
BYND GARAGE
RobertAvitia's Avatar
Drives: 17' 1LT Turbo
how do you remove the shifter trim? tried popping it off with a trim tool but it wouldn't budge so I gave up because I didn't want to brake anything
RobertAvitia is offline   Reply With Quote
Old 07-20-2018, 12:04 AM   #7
Haole
2017 SS
Haole's Avatar
I started at the back by the E brake area and it came right up for me.
Old 07-20-2018, 07:54 AM   #8
RobertAvitia
BYND GARAGE
That’s where I was trying also. I’ll just stop being a puss
Old 07-20-2018, 06:04 PM   #9
RobertAvitia
BYND GARAGE
Just finished mine up
Old 07-22-2018, 12:43 PM   #10
Lord M
Drives: 18 6.2
Yeah, I'll post video links just scroll through to find what you're looking for.
To get to the passenger side vent remove the radio first (smaller screen)
This is for larger screens removal and removal of the vent.
For driver side vent
Old 07-22-2018, 04:34 PM   #11
Haole
2017 SS
Haole's Avatar
well I did the center vents and console trim for now
Old 03-06-2021, 09:11 AM   #12
Saivyia
Saivyia's Avatar
Drives: 2017 V8 2SS Bright Yellow
This looks good, super clean, how is the white holding up?
Saivyia is offline   Reply With Quote
Old 03-06-2021, 12:04 PM   #13
Haole
2017 SS
Haole's Avatar
The white bezel trim eventually peeled some, so I just removed all the plasti dip and went with carbon fiber overlay trim and paint the vent rings with black plasti dip. That has held up nicely now for months.
chrome, how to, removal, vent rings
