10-05-2017, 12:05 PM | #1 |
Loves Camaros
Drives: Red '79 Z28, '24 Blk A10 ZL-1 Vert Join Date: Sep 2012
Different sound inquiry
I have a 2017 ZL-1 M6 that was built in early April 2017. I now have almost 10k miles (I can't stop driving it!) About a thousand miles ago, I started hearing a "different" sound from the engine bay. For the first 9k miles, I would hear the supercharger whine when I cracked the throttle open, and I came to feel that it was normal as most of you do, I'm sure. Since about 9k miles, I now hear a continuous whine of sorts. It's hard to describe, but it's a cross between an old-style cavitating power steering pump and a cicada singing on a warm summer day. The whine follows engine RPM. At idle, it's not there. With the windows up and the sound system on, it's barely audible. Driving with the driver window down, you can hear the sound echo off of a nearby curb, building, or other structure. When I crack the throttle and engage a little boost, I don't really hear the supercharger as I used to because of this whine. There's no other symptom, and the car runs fine and strong as it ever did.
Does anyone have an idea what it might be? My air cleaner's full of cicadas and they're mad? Am I just hearing the supercharger all of the time now? I hope it's not bearings or something. I'll just sit here and Thanks! Tara PS: I am the victim of both the rattling, loose sway bar endlinks, and the high riding front suspension. I plan on taking it in to get the front springs ordered in the near future.
Old and new, sharing space!
10-05-2017, 12:51 PM | #2 |
Drives: 18 ZL1 A10 Join Date: Nov 2008
What exhaust mode are you running?
I noticed a kind of whistle in stealth mode. -bobby
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS |
10-05-2017, 01:08 PM | #3 | |
Loves Camaros
Tara
10-05-2017, 01:45 PM | #4 |
Flyin NOE
Drives: 2018 ZL1 (A10) Join Date: Apr 2017
Is the sound there when you get the SC into the boost side? Thinking it could be a wastegate flutter but I'm spit balling. Anyway you can record the sound and post?
10-05-2017, 02:59 PM | #5 | |
Loves Camaros
Thanks for any input!
10-05-2017, 03:00 PM | #6 |
Loves Camaros
Thanks!
10-05-2017, 04:29 PM | #7 |
Drives: None Join Date: May 2017
Curious if it's the SC belt. The 'vettes are having theirs replaced. Description doesn't sound the same, but it's the only thing I can think of.
http://www.corvetteactioncenter.com/...-afm-1357.html |
10-05-2017, 05:04 PM | #8 | |
Flyin NOE
Having said that, Dethsupport may be onto something with the pulley belt. |
10-05-2017, 08:24 PM | #9 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
Bad idler pulley bearing?
10-06-2017, 07:16 AM | #10 |
Loves Camaros
I hadn't thought of that. I'll dig around under the hood this weekend. I've been so busy this week and last...
Thanks!
10-06-2017, 07:17 AM | #11 | |
Loves Camaros
Thank you for any and all ideas! Tara
10-06-2017, 08:09 AM | #12 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
This was going to be my guess. Belt could also be a good possibility
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
10-06-2017, 09:27 AM | #13 |
Drives: ZL1/335i Join Date: Apr 2014
I'd agree. Could be a worn belt, but there are a whole bunch of idler pulleys on the supercharger belt route.
I'm still not sure what's up with that service bulletin. It lists 2017 ZL1, but the main issue is related to AFM and noise when switching between modes. So that's a little odd. I just checked the belt on my 2018, and it's the same part number that came on the '17 models. So it doesn't look like a production change was made. What's also funny is that the Gates HD belt in that bulletin is longer than the stock belt. I'm not sure why. Usually that's the opposite of what you want to do to limit belt slip in a blower car. That said, I decided to order a Gates RPM belt in the stock size. Why not? It should perform better and last longer than the stock belt. I figure having one in the garage isn't a bad idea. |
10-06-2017, 09:44 AM | #14 | |
Loves Camaros
