06-10-2019, 01:16 PM | #1 |
Drives: Chevrolet ss Join Date: Mar 2019
Top doesn’t go down
Hi,
My 2012 convertible doesn't lower the top. When I press the down button it says unlatch top and not sound or roll the windows down at all, but it is unlatched and free and the cargo net is opened. I can press the up bottom and the windows go down and motor works. What can I do? Best, |
06-10-2019, 02:30 PM | #2 |
Sounds like you may have the buttons function reversed. The up button doesn't do anything with the windows. When pressing the down button the windows should go down, then the top will lower as you hold the button. Continue to hold it down until you hear a beep which is to let you know it's all the way down. I assume the button is the same betwen the model years but who knows for sure. In my 13, the button functions like this, down is toward the back of the car and up is toward the front of the car.
Black GFX / Dynatech Supermaxx LT Headers / FR Black Chrome ZL1 Replicas 275/315 / RDP Tune / CAI / VMAX TB / MBRP SS Catback / Gtechniq CSL & EXOV3 / VTC / RX Catch Can / Valentine 1 / Halo DRL / LED Fogs
06-10-2019, 02:58 PM | #3 | |
06-11-2019, 05:25 PM | #4 |
Drives: 2024Camaro 2SS CE Convertible Join Date: Jul 2013
So if your top is up and you push the up, the windows go down? That part of previous advice is wrong. If your windows are up with the top down, you push the button, the windows will roll down.
06-12-2019, 12:54 AM | #5 |
Yep, exactly. Is like the car thinks that the top is down but at the same time ir days that the top is latched
06-12-2019, 04:14 PM | #6 |
Drives: 2011 VR SS Vert Join Date: Aug 2015
Since you have the cargo net in place it sounds like it may be a sensor that detects you have unlatched it is not working
06-12-2019, 05:03 PM | #7 |
06-12-2019, 06:04 PM | #8 |
You will get a message the net is not in place. The display between the gauges should give you something.
06-13-2019, 07:48 AM | #9 |
06-13-2019, 02:17 PM | #10 |
Drives: 2013 2SS camaro convertible L99 Join Date: Apr 2016
https://www.camaro5.com/forums/showthread.php?t=163839
Disable and delete the annoying vert top clearance net. Try this and see if it works.
2013 2SS L99, Magnuson 2300, 3.6", cog drive, Stainless Works longtube & cats, Solo catback, Rotofab cai, AAM 3.70 gears, MRR rims, tuned by Speed Inc |
06-15-2019, 01:43 PM | #11 | |
06-19-2019, 02:07 AM | #12 |
Any ideas?
06-19-2019, 02:35 PM | #13 |
Drives: 2015 convertible 2SS Join Date: Jan 2018
I had issues with my latch sensor (windshield) causing that annoying alert, it turned out the that latch wasn't pushing the micro switch far enough...so who need a latch sensor anyway, you can tell right in your face if it's latched or not!? In all my cleverness I bypassed it and no more annoying alert but now my frigging to won't fold down! Once again in cleaver mode I wired the micro switch back up and glued a piece of 1/8" rubber to the switch paddle and all good now. If it isn't at the windshield is has to be in the trunk. I'm assuming you checked all fuses. Good luck.
US NAVY Submarine and Destroyer Vet
71 Camaro 496/M22 9" Monster build 70 350/350HP 4spd Corvette 4th Degree KofC Twin boys baseball dad Living in the best village, in the best city being taken over by Socialists in the Peoples Republik of Kalifornia |
06-21-2019, 05:51 AM | #14 | |
Best, |
