Old 04-16-2015, 04:45 PM   #1
camarograna2
Car Enthusiast
camarograna2's Avatar
Drives: 2010 Rally Yellow Camaro 2SS A/T
Send a message via MSN to camarograna2
Squeaking L99
Have a 2010 Camaro 2SS. I have identified squeaking sound in my engine when i turn on my engine that eventually goes away after it is warmed up. My car is not a daily driver. It goes out maybe once or twice a month in the weekend. I have attached a picture of where the squeak is coming from. Need help from my camaro brothers.
1. What is the part called?
2. Should i be worried?
3. Anything i can do myself to solve the noise issue myself? (not mechanical person at all but have basic tools and im guessing i could fix lower level issues since im not that dumb lol )
2010 Rally Yellow 2SS/RS
Performance Upgrades: Custom Flowmaster X system Exhaust Audio Upgrades: Too much to write down. Visit http://www.camaro5.com/forums/showthread.php?t=206016
camarograna2 is offline   Reply With Quote
Old 04-16-2015, 05:57 PM   #2
TheWood
Drives: 2013 SS
Had the exact same. Took back to dealer and was replaced under warranty.
TheWood is offline   Reply With Quote
Old 04-16-2015, 06:43 PM   #3
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
It's more than likely not the ac compressor (circled in red) but your power steering pump. There's a lot of problems with those and if you're still under warranty get it fixed if not change out to the turn one steering ball bearing model. It will be worth it if you do.
Trob85 is offline   Reply With Quote
Old 04-16-2015, 07:17 PM   #4
camarograna2
Car Enthusiast
Thanks for the replies guys.
So im no longer in warranty. Im at 46 k miles and have 5 years with the car. The reason I circled that particular spot was because I sprayed wd40 on it and the squeak went away. Is the power steering pump near or attached to it.
Old 04-16-2015, 08:49 PM   #5
Trob85
Svt lol
Trob85's Avatar
No it's on the upper drivers side. I've never heard of an ac compressor going bad with that few miles since it's not a regular use thing however with only 13,000 miles my power steering pump gets squeaky (especially in the summer) but goes away after it warms up.
Old 04-16-2015, 08:59 PM   #6
TheWood
Drives: 2013 SS
My belt was off by just one notch and it made the squeek.
Old 04-17-2015, 09:06 AM   #7
camarograna2
Car Enthusiast
how did you move it into place?
Old 04-17-2015, 09:12 AM   #8
camarograna2
Car Enthusiast
OK guys so here is the problem. The Small AC belt is off one or two notches from the pulley. Can anyone tell me how it can be moved back into place?
Old 04-17-2015, 09:15 AM   #9
Hippy
Hotwheels
Hippy's Avatar
Drives: Hotwheels Edition
Send a message via Skype™ to Hippy
Loosen the ac unit and reset the belt..
It jumped of from being stretched.
I would replace it
It is only going to give you a problem down the road
Sent from my SCH-I545 using Tapatalk
Parts for Sale
2013 2SS Hot Wheels Edition 734 of 1524
Hippy is offline   Reply With Quote
Old 04-17-2015, 09:16 AM   #10
Trob85
Svt lol
Trob85's Avatar
Crazy I've never seen or heard of that until this thread good call wood. Should be an easy fix just need some help possibly turning the engine.
Old 04-17-2015, 09:45 AM   #11
camarograna2
Car Enthusiast
I would replace it
i loosened the ac unit but there was no movement for me to reset the belt. Can you in a picture point out where i should loosen the ac unit from?
Thanks for the help. I plan to reset the belt in place. Then drive t oreilleys to replace it with a new one.
Old 04-17-2015, 10:31 AM   #12
Hippy
Hotwheels
Hippy's Avatar
I don't have a picture with me..
But there should be the base near the pivit point then the area it would slide to increase or decrease the belt tension..
Make sure you loosen the all
Parts for Sale
Old 04-17-2015, 11:34 AM   #13
FanDamNCSU
Drives: 2010 CGM 2SS/RS - L99
This is just happened to me recently. All you need is a 24mm socket with wrench and manually turn the crank pulley. While you're doing that just push the belt back on with your other hand. Its a very easy fix. If it jumps back off Ill replace it then. But mine has been fine for over a month.
Performance:
Vararam CAI, Vmax Ported Throttle Body, GM Performance Dual Mode Exhaust (NPP), JRE Tune, Hotchkis TVS Stage 2 Track Pack, Vitesse Paddle Shifters, Vitesse Throttle Controller
Functional:
Hex Vents, Elite Catch Can, WeatherTech Digital Fit Mats, Escort Passport Max
Cosmetic:
Heritage Grill, GM Splash Guards, ZL1 Rockers
FanDamNCSU is offline   Reply With Quote
Old 04-17-2015, 12:28 PM   #14
camarograna2
Car Enthusiast
22 or 24 mm socket?
