03-28-2017, 06:34 AM | #1 |
Drives: 2015 Camaro LFX A6 Join Date: Nov 2015
Central Virginia Dyno
Hello.
Anyone know of any Dyno's in the Lynchburg / Charlottesville / Roanoke area? I was in contact with Black Ops Motorsports in Lynchburg but they seem to have ghosted me for some odd reason. Just looking to get on a dyno for a few pulls and AFR readings. Appreciate any input you could offer.
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
03-28-2017, 08:13 AM | #2 |
8.60 @ 157 @ 4200lbs
dyno
Closet place might be Broadview Auto in warrenton va their a Lsx shop with a Dyno
03-28-2017, 09:21 AM | #3 |
Thanks for the heads up. They are about 135 miles from me. Richmond is about 120.
Very surprised no one in Roanoke or Charlottesville has a dyno? Both are about an hour from Lynchburg. Only guy I can find is Lynchburg is ignoring me.
04-24-2017, 07:19 PM | #4 |
Anyone else have any leads for me on a dyno in Central Virginia?
Looking to get on one for a few pulls and AFR readings ASAP. Not trying to travel over a hundred miles for this but may have to...
05-15-2017, 10:00 PM | #5 |
Drives: Z06 wannabe Join Date: Feb 2015
EFI Performance if you come to Richmond.
Apex Focused
05-19-2017, 03:43 PM | #6 |
Drives: 2011 ss Join Date: May 2013
Broadview Auto has sold the business and dyno is gone
05-25-2017, 02:21 PM | #7 |
Drives: 1LE Join Date: May 2015
