10-04-2012, 09:56 PM | #1 |
Drives: 2010 Camaro 2SS L99 SIM Join Date: Feb 2010
AC recharge
Does anyone know where exactly the R134 recharge valve is located? I want to recharge my AC but don't know where it is.
10-04-2012, 09:58 PM | #2 |
2012 Camaro SS
Drives: 2012 camaro ss Join Date: Jun 2012
wrong thread
_________________________
2012 IMB CAMARO SS |
10-04-2012, 10:18 PM | #3 |
10-05-2012, 09:23 AM | #4 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
On a 2-3 year old car you shouldn't need to touch the AC system, nor should you be doing that kind of stuff yourself.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
10-05-2012, 09:48 AM | #5 |
Drives: 2012 LS M6, Black Join Date: May 2009
Why not? If you have a gauge set, know how to hook it up and know how to read it, it's pretty straightforward.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR 1987 Dodge Raider Turbo Project 1986 Mitsubishi Montero 2.4l FI Transplant |
10-05-2012, 10:01 AM | #6 |
H1 OFCR
Drives: 2013 ZL1 Blue Ray Metallic Join Date: Jun 2011
Recharging the refrigerant is easy. But why are you recharging it on a new car?...
Corsa
Rotofab BBK ZL1 Hood/Fascia AAC Afterburners/Sidemarkers Havoc Black Chrome 5% Tint/20% Smoked Taillights |
10-05-2012, 11:28 AM | #7 |
Drives: 2SS/RS Join Date: Sep 2008
Sorry bud but adding freon is one of the easiest things you can do maintenance wise to the car, probably just as easy as adding oil when it's low. So by your same logic that we shouldn't do easy stuff ourselves, we should also go to a mechanic every time your car is half a quart of oil low.
10-05-2012, 11:45 AM | #8 |
Okay, everyone makes a big deal about this kind of stuff. Can you guys please answer my original question instead of asking me one. I have a license to handle refridgerants. Also my car is not brand new. Its 2010 model and has close to 60K miles on it.
10-05-2012, 04:01 PM | #9 |
Drives: '18 HBM 1SS 6m Join Date: Jun 2008
First thing, you have an AC license, so you should know that the only reason a system would need gas added is if it's leaking, and it has to be repaired before you recharge it. Second the Schrader port is in a very obvious location...at the front beside the windshield washer tank. Good luck.
10-05-2012, 04:54 PM | #10 | |
10-05-2012, 07:59 PM | #11 |
Make sure your gauge set can measure both the high side and the low side. You can quickly tell if there's something wrong if your low side pressure is creeping up.
You add refrigerant to the low side, obviously (I hope). Low pressure is after the passenger compartment evaporator and before the compressor. There should be a high side port as well, but that one is after the compressor. If the system is still functioning at all, you can determine which is which by feeling the temp difference on the lines. Hot lines are high pressure, and you do not want to try to add there! If your system has a leak, you can try to detect it with dye, but that's not always successful from a shade tree perspective and may require special detectors. Pulling a vaccuum, boiling everything off, maintaining the vac and refilling is the best way to go about it, and if the system is opened (besides using the ports) in any way, I'd replace the receiver/dryer and consider adding compressor oil according to the shop manual values. And I didn't even ask a question there. John B.
06-15-2015, 12:41 PM | #12 | |
Team LFX
Drives: 2012 Camaro LS Join Date: Dec 2011
your ac recharge kit couldn't even fit on the port, i found mine near the fire
2.5" cat- back Magnaflow exhaust w. resonated x pipe, Roto Fab CAI .. .. JL sound system, Halo fog lights, Escort radar, window tint + turn signals
06-15-2015, 01:50 PM | #13 |
Drives: 2014 Camaro 2SS RS & Ground effects Join Date: Apr 2014
I don't know anything about re-charging AC but ..... nice pic did she come with the car? or was she an option?
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260 |
06-15-2015, 02:03 PM | #14 |
Drives: 2014 2SS/RS Join Date: May 2015
