07-29-2017, 09:16 AM | #1 |
Drives: Anything I want Join Date: Oct 2008
How to add INTERCOOLER RESERVOIR
So we have announced a plug and play Reservoir for ZL1 guys finally. This allows you to be able to check and fill your intercooler as well as add capacity.
07-29-2017, 01:14 PM | #2 |
Drives: '21 ZLE A10 Join Date: May 2012
Great job...just ordered it
07-29-2017, 01:49 PM | #3 |
CamaroFans.com
Great add... so will a reservoir be following this one?
07-29-2017, 03:05 PM | #4 |
Drives: 2017 ZL1 A10 Join Date: Aug 2016
So this will get around having to go to dealer to pull vacuum and fill correct? If so I'm in.... dealer wants $160 to fill and right now have to have special fitting to do it
07-29-2017, 06:43 PM | #5 |
Drives: 2017 ZL1 Join Date: Aug 2016
Why would someone need this exactly? On stock supercharger anyways.
07-29-2017, 07:33 PM | #6 | |
As mlee asked though, would be nice to have bigger reservoir for more coolant capacity, and could ice the system as well... |
07-30-2017, 01:27 AM | #7 | |
07-30-2017, 02:21 AM | #8 | |
I am going to call ADM next week to verify that we will not need to pull vacuum with this system, or that it is high enough to kind of self purge air pockets. If so I am in, if for no other reason as to allow me to do it myself without having to go to the dealer to do it! |
07-30-2017, 05:44 AM | #9 |
Drives: 17 ZL1 Join Date: Mar 2017
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp |
07-30-2017, 06:57 AM | #10 | |
So back in 2016 we developed an LT4 Supercharger kit for the 2016 SS Camaro (http://www.camaro6.com/forums/showthread.php?t=444241) and came to the realization that the factory intercooler system needed the ability to fill it wiith out the special filling procedure. We came up with a group of hoses and coolant tank that fit the bill. This small but useful tank with the correct hoses and placement fit the bill just perfectly. You do not need to pull a vacuum to fill it,you just need to pour it in and check it. Does not get any easier than that.It is also completely reversible. Cheers Andy |
07-30-2017, 07:53 PM | #11 |
Guys just go ahead and get this, it will make your life much easier trust me. I had my system vacuum bled when i removed my blower to do my pulley swap. The dealer did not even get all the air out and my pump began to cavitate and shut down, I ended up having to put a clear hose on the fill valve attached to a funnel filled with coolant and pushed down the pin with a 1/4 inch extension while jumping the IC pump to burp the system. NOT FUN.
07-30-2017, 09:20 PM | #12 | |
Drives: '17 ZL1 Join Date: Jul 2016
07-31-2017, 04:34 PM | #13 |
So how do I order one of these? I stopped by the shop today and the shop was closed... or at least the door was locked. Tried to call as well.
07-31-2017, 08:24 PM | #14 |
