08-17-2012, 04:44 PM | #1 |
Banned
Drives: 2012 Camaro 2SS/RS Convertible, IBM Join Date: Jun 2012
"Used Oil"...
Been thinking.......since most people on this forum change their oil way before it is truly needed, either by ignoring the oil management system or claiming it is "hooey" (sorry for the technical term).
Also, since almost everyone is using some type of synthetic oil, with Mobil 1 being the favorite, and then Royal Purple and what not, all synthetics can go over 5k miles, especially when a bunch of us have the "filtermag" on the filter and the magnetic drain plug. When I have swapped out my oil, it is clean as can be and without any hint of contaminants (smell of oil, discoloroment, etc). So my point: what better way to recycle it then to use it in "lesser engines", a Dodge Neon with 160k miles on it that burns more oil than it leaks, or vice-versa. Perhaps there is some cash strapped kid down the street who could use it. God knows when I was 19, I had a Mercury Marquis that leaked oil at about a quart a week. My neighbor Wally would change his oil every 1500 miles with his Chevy Caprice. So he gave me what he drained and it worked out fine. Of course, the running joke was that Wally should just pour a quart on the street where I parked but that is neither here nor there anymore. BTW, the leak was the back seal, where the tranny mated up with the 460cu.in. big block. It was $375 then to fix it and I was making $375 every two weeks..... I call this a win/win. |
08-17-2012, 04:48 PM | #2 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Won't used oil contain miniscule contaminants like metal and carbon too small to be captured by a filter? Not saying it is harmfull to do so, but if it works, it works.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
08-17-2012, 05:33 PM | #3 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
sure.....put it in your lawnmower
08-17-2012, 05:39 PM | #4 |
Drives: '11 SS M6, '14 SS 1LE, '17 SS 1LE Join Date: Apr 2011
Anyone can drive fast in a straight line, its what you can do thru the curves that matters!
'11 CGM SS M6 ordered in 3/11, '14 BRM SS 1LE from stock in 10/13 & '17 HBM SS 1LE in 11/16 - all from BeckyD!! |
08-17-2012, 06:33 PM | #5 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
I just take it to the local parts store to recycle.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
08-17-2012, 07:52 PM | #6 |
2012 Camaro SS
Drives: 2012 camaro ss Join Date: Jun 2012
Something to consider
_________________________
2012 IMB CAMARO SS |
08-18-2012, 02:24 AM | #7 |
08-19-2012, 06:32 PM | #8 |
08-19-2012, 07:00 PM | #9 |
Drives: 2006 Crownline Join Date: May 2012
Simple, just recycle. I pour it back into the ground, that's where it came from. Right?
08-20-2012, 09:46 AM | #10 |
Drives: 2011 ss Join Date: Aug 2012
True ,first car i had 56 ford, cost me 60 bucks, in 1967. It had several oil leaks, I used what they called bulk oil back then, came in glass 1 quart jars at the thoni gas stations in Nashville, dang wish I had that car now. I'd sure take better care of it now! Thanks for the memories. Tonyko1
08-20-2012, 12:04 PM | #11 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
The thing that would concern me would be how cruddy is the drain pan it is going into. If you could drain it to a clean jug sure, then save it for the DD beater or lawn mower. Not really a loss anyway if you don't reuse it, as it goes to the recycle supply anyway. Just makes the recycled oil that much better, makes up for the really bad stuff I've given them over the years.
08-28-2012, 05:38 PM | #12 |
Member "O'l Farts"
Drives: 2012 SS Coupe/Automatic/Sunroof Join Date: May 2012
I use it for my chain saw as bar oil for the chain. Works great.
09-08-2012, 09:12 PM | #13 |
Drives: 2012 45th Anniversary 2SS Manual Join Date: Aug 2012
+1
Old School Rockford Fosgate 360a2 Amp, Old School 12" Alpine ZR Sub In Sealed Box, ******** Plug & Play RCA Output Harness (No Hacked Wires ), Black CAI Intake, Skip Shift Eliminator
