09-18-2012, 07:12 PM | #1 |
Banned
Drives: 2012 Camaro 2SS/RS Convertible, IBM Join Date: Jun 2012
Cleaning Hints...
I have some spots on the car's paint finish, don't want to come out so easy. Really don't wish to buff them out with any compound or anything that would start to diminish the clearcoat or paint.
Looked up the clay bar I read here many times. Is there one in particular that is better than the other and wouldn't remove more than just the spots? I am thinking they probably come in different types in regards to how abrasive they are... Also, I did see once or more about how to remove tough spots/marks on the windows. Can someone chime in on that or send a link to the thread? Thanks everyone. |
09-18-2012, 07:15 PM | #2 |
Drives: 2006 Z06 Join Date: Sep 2010
mothers makes a clay bar kit that sells at most auto parts stores. The clay will not hurt your clear coat.-just follow the directions on the box.
I had tiny white paint spots on my car...after using the mothers clay bar kit, the paint was smooth and the specks were gone. |
09-18-2012, 07:34 PM | #3 |
Drives: 2011 Chevy Camaro 2LT RS SIM Join Date: Jul 2012
Meguiar's
Just used Meguiar's Clay Bar for the body with Turtle Wax synthetic wax.
For the windows, the best I've actually used is probably right in your kitchen: Water + Vinegar mixed in a spray bottle. That cuts out any swirl marks that you can't get off. Worth a shot. Here's how it looked when I got done the other day: Last edited by CamaroKevin; 09-18-2012 at 07:58 PM. |
09-19-2012, 07:23 AM | #4 |
Drives: 2012 Camaro 1SS/RS L99 Join Date: Sep 2012
+1 Meguiars clay kit ftw!
09-19-2012, 07:31 AM | #5 |
Go SteeleRS/SS
Drives: '11 SS/RS LS3 Join Date: Aug 2011
[QUOTE=CamaroKevin;5591887]Just used Meguiar's Clay Bar for the body with Turtle Wax synthetic wax.
For the windows, the best I've actually used is probably right in your kitchen: Water + Vinegar mixed in a spray bottle. That cuts out any swirl marks that you can't get off. Worth a shot. Did you let him in your kitchen? J/K If that don't work window cleaner with ammonia takes everything off windows. Just don't use it on the inside if you have tint or you'll have purple windows.
K&N typhoon intake
Straight pipes Pfadt springs AAC lighting, 2 sub thump boxes with Rockford 10s 4 20x9" factory wheels powder coated Satin Black |
09-19-2012, 08:14 AM | #6 | |
*In life, there are no nandroids*
[B]
09-19-2012, 09:46 AM | #7 |
Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
All clay is the same. So just buy the cheapest one you can find.
If you want to make your life a little easier and don't mind spending a little more, I would just buy the clay "towel" they have now since its a lot easier to use. |
09-19-2012, 01:11 PM | #8 |
Brewmaster
Drives: 2013 ZL1, 2015 Tundra 1794 Join Date: Jan 2011
For the windows, the best I've actually used is probably right in your kitchen: Water + Vinegar mixed in a spray bottle. That cuts out any swirl marks that you can't get off. Worth a shot. is that mixture safe for tinted windows?
"Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...
holy sh*t...what a ride!" |
09-19-2012, 01:29 PM | #9 |
Drives: 2011 Camaro 1LT RS Join Date: May 2011
I'm getting out of my part time detail biz, and have some of the Original Clay Magic kits left..$20 shipped. Their mild clay is a little more aggressive than OTC Meg's and Mother's. It comes with a bottle of lube too. http://www.camaro5.com/forums/showthread.php?t=246548
09-19-2012, 01:58 PM | #10 | ||
Drives: 2014 Ford Focus ST Join Date: Jun 2009
Here's a great write up by Todd@Autopia. Quote:
The question of this thread is how to remove water spots, which as the article above describes as stubborn mineral deposits on the paint. Since this the focus of this article I will concentrate on their removal. Removing the other type of spots- water etchings- requires resurfacing the paint (either aggressive compound polishing or wet sanding) to repair. The following are the common ways used to treat water spots.
Chemical Cleaning with a Water Spot Remover- This is perhaps the least invasive method. For years people have used, and I have recommended mixing distilled white vinegar with water (1:1). Wash the car first then wipe the paint with the solution and let dwell for 5-10 minutes, then agitate with microfiber towel and rinse off. This works fairly well, and the ingredients needed (vinegar + water) is readily available. The down side is that it works 'okay' and your garage, car, and drive way will stink for weeks! Another viable cleaning solution is Chemical Guy's Water Spot Remover. We are bringing this product into our store after experiencing first hand how well it removes water spots. I know several (extremely high end detailers) who have used this product to remove water spots plastic trim and cowlings! Detailing Clay Treatment- A lot has been written about using detailing clay to remove water spots and for good reason. It cleans most contamination off the paint's surface quickly. Detailing Clay can struggle with some low level water spots only because they have no real thickness. Detailing clay floats above a lubricant and abrades any contaminants that stick above the paint's surface. However many times enthusiasts have clay handy so it is a recommended treatment because it works often. Light Hand/Machine Polishing- Lightly polishing the paint with an ultra fine abrasive polish will scrub the water spots clean and well and increase the gloss and clarity of the paint. For hand polishing consider Meguiar's Ultimate Polish. For machine polishing team up a soft foam finishing pad (such as a Lake Country Black Pad) with a an ultra fine machine polish like BLACKFIRE SCR Finishing Polish or Menzerna SF4500 (the same exact polish used at the Mercedes Factory for assembly line refinishing as a last step for ultimate gloss). Pre-Wax Paint Cleansing Lotion- "Paint Cleaners" are a great choice for removing light water spots. Paint Cleansing Lotions are design to deep clean the paint and prepare for a fresh coat of wax. Many wax or paint sealant manufacturers make paint cleansing lotions that clean the paint and prime it for their wax/sealant. They use either a chemical cleaning solution or a fine polish or a combination of both. The two best I have used are BLACKFIRE's Gloss Enhancing Polish or Utlima Paint Guard Prep All In One Cleaner Waxes Cleaner Waxes or AIO's combine a wax or sealant with the properites of a paint cleansing lotion. They are designed to clean the paint and protect it one, time saving step. KLASSE AIO is a classic in this field, where BLACKFIRE Total Polish N Seal uses the latest in technology/advancements. You can apply most AIO's by hand or machine. If applying by hand (like a paint cleansing lotion) you want to work into the paint with a foam applicator with a little bit of passion. These are some of the options of removing water spots. Depending on your goals each can work. After using Chemical Guy's Water Spot Remover, I am excited to be adding this as an addition to our growing Chemical Guy's line up. It will make a viable cleansing option and should be available shortly. Comments, questions, suggestions are always welcome! Hope this will get you in the right direction. |
09-19-2012, 07:56 PM | #11 |
Swirl marks on the windows, not the paint. I usually get swirl marks from wiping the windows with regular window cleaner. Water + Vinegar cuts those window swirl marks out.
Been hearing it can change the color of your tint to purple? I am not completely sure about that though. I have a slight tint on mine, but have only used it on the exterior of the windows so far. I really can't say for sure. I'll try to look into it and let you know. |
09-19-2012, 09:18 PM | #12 | |
Drives: 2010 2SS/RS,M6,Black w/CGM Stripes Join Date: Jan 2010
Sent from my DROID BIONIC using Tapatalk 2
3" RDP Motorsports aggressive cat-back exhaust w/ x-pipe, Vararam CAI, Hurst's short throw shifter, Gary's Customs painted bowties, Ofer's HID DRL/Fog Light wiring harness, Kelvin 8K HID DRL bulbs, ZL1 grille. Johnson's window tint film, LSR lowering springs, Metra dash kit with Pioneer In-Dash DVD head unit. |
09-19-2012, 11:03 PM | #13 |
Switchin' n Twitchin'
Drives: 2011 Camaro Join Date: Nov 2010
He means streaks when cleaning glass...
I am not childish, you're just being a poopy head!
09-20-2012, 12:01 PM | #14 | |
Drives: 2010 Mazdaspeed 3 Join Date: Mar 2012
All clay sold in the USA has to be sold under the patent that is owned by clay magic, but it is not the same nor is it sourced from one manufacturer. Cheaper clay formulas (as well as really aggressive clay forumulas) are more likely to scratch paint. |
