Old 08-05-2015, 12:34 PM   #1
Scalded Dog
Scalded Dog's Avatar
Drives: 2011 1LT
Service Air Bag.. WITBB?!?!?
Yesterday, I had a passenger in the car, and some stuff (light blankets and pillows) filling the back seat. The back seat cargo was not heavy, nor was is stuffed tightly... it just sort of filled the back seat up.
The entire drive (20 miles), the "Service Airbags" message was displayed on the dash, going on and off. The "Airbag on/ off" indicator light kept randomly toggling back and forth the entire drive. Bells and warnings made the drive less than enjoyable.
After I had dropped my passenger off, I removed the stuff from the back seat. Then I had my wife go for a drive (she is the same size/ weight as my previous passenger was) with me. I could not get the "Service Airbag" warnings to activate at all... everything seems to work just fine now.
Are there sensors for the airbags in the rear seats or the seatbacks? Could something in the back seat have been pressing on a sensor? If so, why? Any other theories on why this happened?
("What in the blue blazes?!?")
Scalded Dog is offline   Reply With Quote
Old 08-05-2015, 12:45 PM   #2
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
hmmmmm.... who is this "passenger".... does your wife know about this "passenger".... hmmmmmm
no sensors in the back seat. there is a seat sensor in passenger seat to detect occupant size. if you under warranty I'd have it checked out... it may have tripped an airbag code
maddoggyusa is offline   Reply With Quote
Old 08-05-2015, 06:57 PM   #3
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
passenger seat occupancy sensor may be the problem. was the seat all the way forward or back? may have tugged on a wire. Mine went out 2 years ago.
GVA 45TH 2SS is offline   Reply With Quote
Old 08-05-2015, 07:05 PM   #4
Eric Baker
Drives: Black/Black 2SS/RS 6M
If the passenger wasn't sitting normally in the seat, like if they sat off center or crossed their legs or something, the weight sensor can get inaccurate readings. Or if there was stuff on the floor behind the passenger seat putting pressure on the back of the seat, it could do the same thing.
Eric Baker is offline   Reply With Quote
Old 08-05-2015, 07:34 PM   #5
mySSt
mySSt's Avatar
Drives: '11 SS M6, '14 SS 1LE, '17 SS 1LE
No passenger air bag sensors in the back seats. Sounds like the problem is one of what was described above.
Anyone can drive fast in a straight line, its what you can do thru the curves that matters!
'11 CGM SS M6 ordered in 3/11, '14 BRM SS 1LE from stock in 10/13 & '17 HBM SS 1LE in 11/16 - all from BeckyD!!
mySSt is offline   Reply With Quote
Old 08-05-2015, 08:40 PM   #6
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I had this happen coming back from OSW. There are a couple threads on it. I adjusted the drivers seat as I had readjusted it for racing and I removed the radar detector case I had stuffed under the passenger seat. Problem has not reoccurred.
If the sensor is bad, the sensor alone is about $300.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
Old 08-05-2015, 09:26 PM   #7
flyer08
Drives: 2010 2SS/RS
Happened to wifes '11 LLT a few months ago. Airbag sensor went bad and it's around $280 to replace last time i looked up the part cost
flyer08 is offline   Reply With Quote
