08-22-2015, 07:56 AM | #1 |
Drives: 2011 Camaro 2SS RS L99 Vert Join Date: Aug 2015
Best Flash Drive for Camaro 2SS
I've experimented with the usb access to music. Namely tried portable memory. I tried a 4GB flash drive and it worked perfectly. Then I tried a 500GB portable drive. It didn't even discover it.
I was thinking about buying a 128GB flash drive USB 3.0 but I'm worried it won't work. http://www.bestbuy.com/site/pny-turb...&skuId=3198009 What do you think? |
08-22-2015, 09:42 AM | #2 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
well there is a limit as to how many songs you can use, as the infotainment system on a 2011 (which is what you have) has a limit of 10,000 songs/files that it will detect, you can find that info in your manual, pg. 7-20, depending on what bit rate you used for your mp3's will depend on how big a drive you can fit them all on. At the standard bit rate for mp3's (128) you can easily put roughly 4500 songs/files on a 8 gig drive. SO with that in mind, you really don't need anything bigger than about a 16 gig flash drive.
08-22-2015, 09:51 AM | #3 |
Doing what I like to do
Drives: 1963 Landrover Join Date: Nov 2013
There you go SIR NUKE , once and for all you proved that bigger is not always better !!!
08-23-2015, 12:36 PM | #4 |
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
I have an older version of this 8GB but you are better off getting the low profile drive. it stays out of the way and only projects out about 1/4"
http://www.bestbuy.com/site/sandisk-...&skuId=9090295 |
08-23-2015, 05:28 PM | #5 | |
Edit: Changed over to the 32GB one. Should be more than enough memory. Last edited by yescats; 08-23-2015 at 08:05 PM. |
08-23-2015, 05:39 PM | #6 | |
Drives: 2011 Camaro 2SS/RS Convertible and: Join Date: May 2014
A 128GB Flash can hold 128,000 songs. THAT'S A LOT OF MUSIC you carry!
Currently in my Garage: 2011 Camaro 2SS/RS Convertible | 1980 Corvette Stingray | 1981 Firebird | 1968 El Camino | 2007 Crown Vic Police Interceptor | 2001 Silverado | 2001 Blazer | 1965 Chevy C-10 | 2007 Harley Softail Custom | 2013 MX-5 in Copper Red Mica | 2000 Corvette Convertible | 2010 Corvette Grand Sport | 2006 Audi A3 Turbo | 2008 BMW 328i |
08-23-2015, 05:40 PM | #7 |
I have a 64G thumb drive with a mix of MP3 and FLAC and my 2010 won't even recognize the drive. I fear it may not see anything bigger than maybe 32G, but don't have one to try.
08-23-2015, 05:58 PM | #8 |
Drives: 2012 2SS/RS Auto Convertible Join Date: Jun 2014
I use a 64gb formatted in exfat format. It takes forever to read, but it works. I'm going to downsize to a 32g since it reads quicker. Right now it takes literally 10 minutes for the dice to read.
Sent from my SAMSUNG GALAXY S6 EDGE using Tapatalk Pro |
08-23-2015, 06:47 PM | #9 |
well here is what I have done......I put the drive in my car and allowed it to load. I never take it out.....unless I need to add more music. This way.....when I get in my car, turn it on, it starts playing IMMEDIATELY....and never misses a beat. NOW, if I take it out, then it will a little while to read and start to play.....but it only does this once.
08-23-2015, 08:29 PM | #10 |
Drives: 2014 Camaro 1LT/RS Join Date: Dec 2014
08-23-2015, 08:33 PM | #11 |
08-23-2015, 08:47 PM | #12 |
Montani Semper Liberi
Drives: 2011 Black 2SS/RS w/ IOM stripes Join Date: Feb 2010
have a few different ones, ranging from 8-32 GB, all work but the ones with a ton of songs take forever to index, usually just go with one of the 8's with all my favorite bands on each. Currently rocking out to Seether
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint |
08-23-2015, 10:21 PM | #13 |
Lake Erie Monster
Drives: 02 Hyundai Santa Fe and 13 300 Join Date: Aug 2012
My 13 drops the thumb drive every other drive cycle. I have to listen to my iPod classic using an aux cord because it takes forever to index. I recently rented a 15 Charger for our family trip and it took the Uconnect 10 mins to index. Come GM keep up!
Everything I say is to be taken as an opinion and not fact so don't get upset over words that spill out of my head.
GO CAVS! |
08-24-2015, 12:23 PM | #14 |
KaBoom1701
Anything over 300 songs takes forever to index......
I just keep my song count around 300 and it will start playing within a few secs.
Mods:
