12-10-2009, 11:42 PM | #1 |
Drives: 2010 SS F1-D procharger, Join Date: Jul 2009
MY M6 SHIFTER PROBLEM
MY SHIFTER JUST WENT LOOSE AS IF IT WASNT CONNECTED TO ANYTHING AS I MADE A TURN. LUCKILY I WAS CLOSE TO HOME. HAS ANYBODY ELSE HAD THIS PROBLEM??
12-11-2009, 07:24 PM | #2 |
Drives: Pontiac G8 GXP Join Date: Oct 2009
have you found out what happened?
12-18-2009, 03:01 PM | #3 |
More then meets the eye!
sounds like the shifter pin came out.
2010 2SS/RS, M6, OBX 7/8" l/t headers, with high flow cats, MBRP full 3" exhaust, Whipple supercharger, 3.875 pulley, ID-1050X 1260CC injectors, JRE rough idle street blower cam kit, ZL1 fp, ZL1 fpcm, ZR1 3 bar map sensor, cold air intake, Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidamper, MGR shifter, and tune by Jannetty Racing.
Similar Threads | ||||
MGW PROTOTYPE SHIFTER IS IN!!! STAY TUNED!!! | MGW | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 110 | 04-13-2012 09:30 AM |
MTI Racings new 2010 Camaro short shifter | MTI Racing | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 24 | 08-23-2009 08:07 PM |
Potential Huge Problem.... 2010 Camaro Nose Cracks (UPDATE: NOT A PROBLEM AT ALL!) | Nine Ball | 5th Gen Camaro SS LS LT General Discussions | 328 | 05-03-2009 08:55 PM |
Dumb question (sorry in advance) Hurst Shifter | 2Muchmark | 5th Gen Camaro SS LS LT General Discussions | 0 | 04-16-2009 04:52 PM |
camaro update (husrt shifter, cgm) | gss9909 | 5th Gen Camaro SS LS LT General Discussions | 24 | 03-27-2009 06:33 PM |
