08-09-2014, 11:16 PM | #1 |
Drives: 2012 2SS 45th Join Date: Jun 2012
6L80E Shifter pattern
I just installed B&M Pro Ratchet shifter on my Camaro
and I noticed there is some position that we don't use. 6l80E has a position like 4speed trans PRND321. If I put it in there, those 2 will be just "S" so patturn is PRNDSSS. I kinda feel like those spot is for TUTD, but If I can shift like PRNDS21 that'll be awesome. Feel like it's just like changing mode electronically like just a switch. so if any other stand alone can program to change pattern like that, That will be awesome. Does any one know how to do this? or this is impossible to do? Thanks
2012 Camaro SS 6AT
DOD/VVT delete, TSP Turbo cam, pushlod, COMP675 spring, Lingenfelter twin fuel pump, ID-850 injector, ZR-1 3bar MAP sensor, port matched head and LS3 intake valve, manley ex valve, ARP head stud. no weeds diverters, MagnaFlow 3" X pipe and street axleback Hellion Twin Turbo Kit :Turbonetics BB Billet 64mm 4' intercooler E-Boost2 with twin 4port solenoids, Turbosmart ultragate38, Tial Q BOV 2Bar SD tune |
08-09-2014, 11:21 PM | #2 |
Drives: 2010 2SS/RS Join Date: Jan 2013
U put a aftermarket 6l80 shifter? Any pics?
And yea on my truck 6l80 as well it would go down 2 times after the S or M Who knows what those do |
08-09-2014, 11:45 PM | #3 |
Still waiting for shifter boot for manual trans and still have some stuffs to do
2012 Camaro SS 6AT
08-10-2014, 12:15 AM | #4 |
Looks badass
Sure wish B&M made one with tap shift on the handle Or like The G8s where u can hit it up or down |
08-10-2014, 01:09 AM | #5 |
Yea, I was thinking to use G8one, but I've wanted to have ratchet shifter and was gonna do 4L85 swap, but decided to go beef up 6L80E. so it doesn't do anything, but just a feeling making me happy.
2012 Camaro SS 6AT
08-10-2014, 08:06 AM | #6 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
It will do nothing for you these are highly controlled by electronics so it sees the same thing as sport mode. Unlike the 4l80 the lets you decide the lower gear 1,2,3,d.
08-11-2014, 02:15 PM | #7 |
I'll try contact some company that sells standalone TCM.
I'll just give up if they say no control
2012 Camaro SS 6AT
08-11-2014, 06:46 PM | #8 |
Drives: 2016 Camaro SS Join Date: Jul 2014
How are you operating the tap shift using that shifter?
08-12-2014, 04:54 AM | #9 |
I use paddle on the steering wheel.
I hope I can win "Hex code fight" with TCM and activate those 2 extra spot. But, there is so many company sells Tap shift on shifter. I hope B&M makes grip like TCI" outlaw 2 buttons on grip!
2012 Camaro SS 6AT
08-12-2014, 04:45 PM | #10 | |
I'm pretty sure that one of the buttons on the TCI shifter is for a trans brake and the other is for nitrous. I like what you are doing here! Good luck. |
08-20-2014, 02:38 PM | #11 |
Drives: 2010 Camaro SS2 DeadBLK Join Date: Nov 2010
I tried to install a pro shifter on my 6L80e but gave up... A functioning ratchet shifter on these would be super kick ass but what you have here is cosmetic. You have no use for the last 2 gates. That is the shifter I wanted for my future 4L80e conversion.
Good luck! post a video when you figure it out.... Would be awesome if the last to ratchets spaces triggered the up and down tap shift! The only functional choice auto guys have is: CFD tap buttons on the shifter Hurst comp paddle and shifter combo CFD manual boot and shifter knob cosmetic adapter
08-20-2014, 06:46 PM | #12 | |
Drives: 2013 Camaro SS and 2016 Camaro SS Join Date: Jun 2014
08-26-2014, 11:29 PM | #13 |
Here is little update.
I bought shifter boots for manual trans and I think I'll need some sawing right there. I'm trying to make switch panel on the steering wheel right now, so switches are just hang and float there. Shifter works just fine as change PRNDS. I locked shifter as 2 speed operation so don't go other 2. And I just ordered 3' long Super duty shifter cable. I have turbo and cutout around cable, so I just want to make sure its secure from anything. I'm still thinking to convert to build 4L85E just because of the cost. and that'll be awesome work with this shifter
2012 Camaro SS 6AT
09-04-2014, 04:31 PM | #14 |
Although I may be a bit biased, I have to say, that B&M shifter looks really nice in your Camaro.
