12-05-2014, 11:19 PM | #1 |
Tires last 9000 miles
I have my original set of tires on and they started getting quite dangerous at 9400 miles I unfortunately did not get any track time but have a blast with the carthis was without any tire rotation front and rears need replaced
12-06-2014, 12:46 AM | #2 |
Drives: '16 C7 Z51 Join Date: May 2012
Are these Z/28 tires? If so, it's normal; actually sounds above average.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
12-06-2014, 07:49 AM | #3 |
Drives: BAC Mono Join Date: Apr 2013
3200 miles, including 4 track days, down to 2/32. Maybe another 1000 (dry) street miles on them left. Wearing better than I anticipated as well.
2014 Z/28, White
"I wasn't asked to make it cheap...I was asked to make it FAST!" Mark Stielow, the new Z/28. |
12-06-2014, 01:30 PM | #4 |
If I may ask, what cold/hot pressures did you use? And how much camber did you have front and back?
12-06-2014, 04:23 PM | #5 | |
Tread face wear looks amazing even. Shockingly so to my eyes. That is what a well engineered suspension gets you
2014 Z/28, White
12-06-2014, 07:54 PM | #6 | |
The manual states no less than 26PSI, yet Pirelli site states 2bar (29 PSI) hot, which would require 22-23 PSI cold. I just don't think 22-23PSI is acceptable, so I'll follow GM's recommendation of 26 PSI minimum. An alternative way would be starting 26 PSI cold, then keep bleeding until 29 PSI hot, but who has time for that?
12-06-2014, 08:27 PM | #7 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Wow thats great we corded out our Goodyears at about 3000mi on our 1le
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
12-06-2014, 08:52 PM | #8 |
G:2s last quite long (15K?) in our experience, until you go to track with them.
