10-20-2014, 10:23 AM | #1 |
So-Cal Race team!!
Drives: Tahoe LTZ,2010 2SS/M6 Camaro Join Date: Apr 2009
Pedders XA Broken endlink tab Help
So last weekend I broke the Endlink Tab mount of my front XA coilover Does anyone have a Bad set of fronts they want sell I only need the Coilover Mount piece the shock is fine ....tried to weld it but didn't work it was not a very good weld so if anyone has one to sell please hit me up I need ASAP for Next weekend ....
WE RACE DEEP!!
BBK Intake, Flowmaster AT cat back Barton shifter,Painted stripes,,Heritage grill,LED DRLs, Smokin Tires!! |
10-20-2014, 10:41 AM | #2 |
So-Cal Race team!!
Photo....
WE RACE DEEP!!
10-20-2014, 12:08 PM | #3 |
Drives: G5.R Join Date: Sep 2010
Wow sorry to hear it. I'd take it to some one who could weld and give it a send try. A weld done right should be stronger the the original.
12-19-2014, 03:27 PM | #4 |
So-Cal Race team!!
Wow other side broke the same way......
WE RACE DEEP!!
12-19-2014, 05:44 PM | #5 |
Drives: 2010 2ss red LS3 Join Date: Aug 2011
I believe the strut cartridge is filled with oil and under pressure(nitrogen). Which means DO NOT weld before disassembling...it will explode when welded!
Pedders Pace Car Kit with ZL1 sway bar conversion & camber bolt kit.Lowered 1.5". 1LE tires & wheels. CAI air intake. Anvil CF rear spoiler.MGW shifter. 1 7/8" Kooks LT headers & HF cats.V-Max ported TB. Tuned.
12-19-2014, 06:37 PM | #6 |
So Cal Race Team
Drives: 2013 Camaro Join Date: Mar 2010
12-22-2014, 09:11 PM | #7 |
Drives: 2006 GTO Join Date: Dec 2009
How did that happen?!?
12-23-2014, 01:19 PM | #8 |
Drives: 2011 Camaro SS/RS - 2004 Silverado Join Date: Mar 2010
What kind of end links and sway bar do you have?
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80 2004 Black Silverado 1500 2WD Regular Cab, Short Bed -5.3 LM7, 4L60E, 3.42, G80 2014 White Caprice PPV -6.0 L77, 6L80E, 2.92, G80 |
12-23-2014, 01:42 PM | #9 |
Are you interested in just replacing the lower front mount or having spare Pedders parts including shocks, mounts, springs, etc. ??
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
12-24-2014, 01:34 PM | #10 |
Something is wrong in your front suspention! Looks like to me the tab was broken from front<-->rear movement. The only load on the tab should be up down. Also the end links do not appear to be in good shape. Do the end links swivel well? Are they set up 90* apart? Does the Anti-roll bar rotate freely and have little side to side movement and is firm in its mounts?
12-24-2014, 01:41 PM | #11 |
There is a rub mark on the end link bar, what was it rubbing? I should not rub any thing!
12-24-2014, 05:10 PM | #12 |
So-Cal Race team!!
Sure what do you have to sell and how much
WE RACE DEEP!!
12-24-2014, 05:12 PM | #13 | |
So-Cal Race team!!
WE RACE DEEP!!
12-24-2014, 06:14 PM | #14 |
So-Cal Race team!!
When it broke it was rubbing the tire ....... ..
WE RACE DEEP!!
BBK Intake, Flowmaster AT cat back Barton shifter,Painted stripes,,Heritage grill,LED DRLs, Smokin Tires!! Last edited by ddunerider; 12-24-2014 at 06:27 PM. |
