07-28-2014, 05:01 PM | #1 |
Oil Filter
I know we talk alot about oil, how about the filter? What do you use? I have a V6.
Thanks, |
07-28-2014, 05:21 PM | #2 |
A good oil filter:
AC Delco PF2129 K&N Pro Series PS-7003 Mobil 1 M1C-254 Dorman 65212 magnetic oil drain plug M12x 1.75 x 15mm And of course, Mobil 1 5w-30 full synthetic engine oil. |
07-28-2014, 06:54 PM | #3 |
Native Floridian
Drives: 2014 - ZL1 / 2003 - Corvette Join Date: Oct 2013
I use Mobil-1 oil filters on all of my cars and boat.
07-29-2014, 12:57 AM | #4 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Can't go wrong with Wix either.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
07-29-2014, 01:05 AM | #5 |
Napa Gold and Pennzoil Ultra Pure Plus. So far so good and Pennzoil does offer a warranty program if you track your services. They're very confident about their product. No I don't work for either company, I just like what I see.
Todd in Vancouver
'14 ZL1 Camaro '67 Camaro SS Pro-tour in process How hard can it be... Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession |
07-31-2014, 08:51 PM | #6 |
Drives: "Kara Zor-El" 2017 2SS HBM Join Date: Jul 2014
I use AC Delco filters for the past 10-12 years without a problem.
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!! What? Dangerzoooooone. |
07-31-2014, 09:29 PM | #7 |
Drives: 2014 2SS/RS - SIM Join Date: Apr 2014
For my first oil change at about 1500 miles this and I will be running these from then on.
07-31-2014, 10:07 PM | #8 |
Drives: bicycle Join Date: Jun 2014
The amsoil EA15K50. Designed for absolute efficiency down in the 20 microns levels
07-31-2014, 11:11 PM | #9 |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Efficiency isn't everything, however. You really want to balance efficiency with flow.
Filtering to 99.9% doesn't mean much if you only get 10% of the oil flow your engine needs. JUST SOMETHING TO THINK ABOUT, not bashing anyone's choices or recommendations. I use Purolator Pure Plus filters, but I don't go 15,000 miles on an oil change. I still change every 5k, because my miles aren't easy miles. That being said, I run Shell Rotella-T 5w40 synthetic oil. |
07-31-2014, 11:41 PM | #10 |
Drives: 2015 2SS/RS Summit White Join Date: Nov 2008
I don't know, I put 122k on my '97 Z28 with AC Delco, no problems
I put 93k on my 2002 Cavalier with Fram extra or tough guard, Engine was fine no problems I've put 64K on my Cobalt with Fram Extra guard or Tough guard no problems. I guess I'm going to use AC Delco in the new Camaro because I've been spooked by all the bad words I've seen about Fram but I never had any trouble with them. Maybe I was just lucky, I drive my cars easy and change Mobil 1 every 5k at the longest. |
08-02-2014, 06:12 PM | #11 |
Mobil 1 M1C-254 . Mobil across the board for me
The DREAM is free... It's the HUSTLE that is sold seperately
08-04-2014, 08:39 PM | #12 | |
I don't know of an oil filter that would do this. Although your heavy foot can do this to a filter,,, and I explain myself on how you foot can do this to a filter. (Filters have a bypass spring loaded to aprox 9 to 18 lbs depending on the filter design, bypass will activate every time there is a spike in oil pressure which normally is seen during cold starts or wide open throttle runs. So if you filter claims that it is absolute efficient which oh by the way not many filters in the market can claim, but it only filters 10% of the time you better look for a different filter. True,, but who would design an oil filter that would only flow |
08-04-2014, 11:46 PM | #13 |
C5 Best Gen
Drives: 2015 Camaro SS Join Date: Aug 2013
AC Delco filters for me. I don't use anything else, they do the job
08-05-2014, 12:44 AM | #14 |
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH Join Date: Jan 2014
if you like Wix/Napa Gold, check this out:
http://www.fleetfilter.com/ I bought a case (12) for $5 each delivered. That's a savings of a couple of bucks per filter, not to mention the time and gas spent running to parts store several times.
Consensus is, by definition, a lack of leadership.
