Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 02-27-2016, 09:31 AM   #1
hesster
hesster's Avatar
Drives: '10 C5 SS, '77 Bandit T/A
BL-5000SLX Quick Jack
Assembled my Ranger Quick Jack yesterday in prep for installing extensive suspension mods. Model BL-5000SLX. This thing works great!
hesster is offline   Reply With Quote
Old 02-27-2016, 09:35 AM   #2
Silver14
Drives: 2014 SIM 2SS
Looks awesome, I've been considering one. Please let us know what you think of it after you use it for a while.
Silver14 is offline   Reply With Quote
Old 02-28-2016, 07:38 AM   #3
driser
driser's Avatar
Drives: 2010 Camaro SS
quick jack
Mine is being delivered Tuesday, and can't wait to use it.
Any problem finding a good lift point on the car?
driser is offline   Reply With Quote
Old 02-28-2016, 10:11 AM   #4
hesster
hesster's Avatar
I was real careful where to lift it. Note the position of the jack in relation to the car's underbody. Use the "Tall" Blocks. 1st pic is the front, 2nd is the rear (if you look carefully you can see the rubber block). Position the jacks just inside the rocker. Kinda hard to see the rubber blocks in these photos since they are on top of the jack in the pockets. I suggest you take your time assembling, and don't cut any corners. Heed the warning on not stopping the rise once engaged to the body and ready to lift, as none of these lifts are designed to hold the load until you get it at least 1/2 way up. So raise it until you get the blocks to just seat, check they are positioned correctly, and then raise it up 1/2 or full until the lock bar engages.
Old 02-28-2016, 02:28 PM   #5
blakjak55
drinks virgil's
blakjak55's Avatar
Drives: 2010 2SS M6
Nice but good lord expensive.
2010 2SS/RS M6 - CAI Intake - Borla Stinger - VTC - 3.91's
Eibach Sways - LG ZR28's - BMR Springs - 285/35 Squared
blakjak55 is offline   Reply With Quote
Old 02-29-2016, 08:08 AM   #6
driser
driser's Avatar
Quick Jack
Thanks for the info and pictures. I'll be trying it out this weekend.
Old 02-13-2017, 08:19 AM   #7
sswt00ss
Visualize°Design°Create
sswt00ss's Avatar
Drives: '18 CTS-V & '13 ZL1
Bump from the dead...can you provide anymore follow up feedback?
I'm looking into the 5000 Series for both my 2000 & 2012 SS's. You mentioned using the Tall rubber blocks, which would be the 3" high ones as seen on their site.
I'm tired of having to use one floor jack to raise the 2000 high enough to then use a second to raise the car to place on floor ramps/ jack stands (car sits to low to drive up ramps without catching the front bumper causing damage). I'm under both a lot for oil changes, tires changes, exhaust work, suspension, etc. These look to be a very simple remedy.
Also, are there any safety locks, in the event of a hydraulic cylinder failure to keep things from getting ugly?
I guess I'm looking for additional thoughts before moving forward with a possible purchase. Thanks for your time. Cheers!
sswt00ss is offline   Reply With Quote
Old 02-15-2017, 02:11 PM   #8
BRZN
BRZN's Avatar
Drives: 2012 1LT
Yes, they have safety locks in two different height positions. For simple things like oil changes I'll just use a set of Race Ramps. They sell extensions for lowered cars and they work well. Exhaust work I use jack stands. The Ranger takes up all the space on the sides of the vehicle between the front and rear wheels making side access impossible. Suspension work, brake jobs and tire changes the Ranger is the way to go.
The Ranger Jack is nice, but takes a bit of time to position it correctly under the car to lift it.
BRZN is offline   Reply With Quote
Old 02-20-2017, 06:35 PM   #9
DBHWT
DBHWT's Avatar
Drives: 2013 SS 1LE
So it goes under the floor area and none of the pinch welds are used, correct ? Thnks for any info
DBHWT is offline   Reply With Quote
Old 02-26-2017, 10:41 AM   #10
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Just got the 7000 for my birthday, and it made the coil over install a breeze. After lowering the car, I could still get each side under the car without issue. I got the 7000 because I also want to use it for my Avalanche too. Great piece of gear if you don't have room for a two or four post lift.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 03-05-2017, 07:02 AM   #11
BRZN
BRZN's Avatar
Drives: 2012 1LT
The two pieces of the lift, one on the left side of the car, and one on the right, need to be parallel to each other. On the Camaro the best place I can get the lifts are on the pinch welds, I most certainly wouldn't lift the car by using the floor as a lifting point. There are urethane blocks provided so it's being lifted with a forgiving material and hasn't caused any damage.
Lifting my GTO from the pinch welds:
Letting her back down:
Old 06-25-2017, 11:19 AM   #12
NipTuckTaxi
NipTuckTaxi's Avatar
Drives: 2010 Camaro 1SS
Use mine all the time. Pinch welds lift fine. Driveshaft axles and rear diff swap yesterday with quick jack. Angled the blocks to pick up just the front or rear of my f150 for small jobs. Oil changes and brakes on wife's Pontiac G8. Thing just paid for itself!
2010 SS: ERL 416; AGP TT; Century Super 6L80; Strange S60. Supporting mods in between. 650rwhp\ 700 rwtq.
NipTuckTaxi is offline   Reply With Quote
Old 06-25-2017, 11:53 AM   #13
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
How does the 7000 work with your avalanche. I was thinking of going 7000 due to my truck (silverado) and car
Sent from my iPad using Tapatalk
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
Old 02-15-2018, 10:22 AM   #14
Silver14
I know it's bumping an old thread, but this helped me make a decision to order the 7000slx. Free Jackpack included through Februrary. We have the Camaro, a Tahoe, and an Acadia so the 7000 should work on all of them.
If you order one ask for Jasmine at ext 162, she was very helpful and able to answer all of my questions.
