06-27-2011, 04:45 PM | #1 |
Loperformance Motorsports
Drives: 2011 2LT Join Date: May 2011
AAC Halos and keep the stock halos
Seen a lot of halo installs on here and thought I would show you all a couple things I did to make them look a little better(my opion) and sure make it to where the AAC halos fit way better. I painted the AAC halos black and used denature alcahol to clean the sem's off. Before painting put some 1/8" tape over the sem's. It really make the lights seem brighter and they blend into the light housing better. Also, for better fit and all around looks I took a drimmel and ground down the surface on the stock halo rings. Both will fit in the housing a lot better and you will have the stock and the AAC's also. If you prefer to run both you just have to put the AAC's on a swith. Hope someone can use this tip here and as alway's, Have fun doing it!!! Good Luck!
06-27-2011, 04:47 PM | #2 |
One last thing! Grind down the bottom lip of the light housing to make the AAC's fit flat on the housing. Then both halo's will fit into light.
