Old 10-26-2016, 10:15 AM   #1
ABMLS3
ABMLS3's Avatar
Drives: 2010 Aqua Blue Camaro 2SS/RS
Opinions needed: possible bad injector?
*Please read everything before coming to a conclusion and don't just look at the pictures*
So last night I was driving my car and when I got on it, it made sort of like a squeaking noise coming from the engine bay than the car started misfiring and popping. Pops during acceleration and deceleration. When I got home I figured out which cylinder it was and checked the spark plug. The ceramic piece on the plug was cracked so I put a new one in. Started it up and it idled fine until I held the gas steady at around 1500 rpm than the misfiring came back. Took it for a drive about half a mile down the road came back and the new spark plug was completely white.
I did a little researched and found out that cracking of the ceramic insulator is due to high temps. If my injector was bad it would be running lean cause high temps and Mis firing.
It is only the one cylinder with a bad spark plug which would cause me to think that it would be the injector.
First picture is the cracked ceramic plug that was originally in (the piston didn't hit the plug and close the gap, I'm holding it upside down and the ceramic is just resting on the ground electrode.)
Second picture is the new plug I drove with for about half a mile
What do you guys think? My first guess would be bad injector possibly but I'm not sure. Any tests I could do to pinpoint the issue?
UPDATE: just finished changing all my spark plugs, found two more plugs with cracked ceramic.. now with all new spark plugs it's running perfect. Maybe it was just time for new plugs? I'll drive it around a little and check the spark plus again to see how they look
Power Source Performance Turbo Kit
416 C.I ,TH400
Instagram: TomTraube
COTW ABMLS3 Build Thread
ABMLS3 is offline   Reply With Quote
Old 10-26-2016, 11:24 AM   #2
ilir14
ilir14's Avatar
Drives: Camaro ss 1le
Hate to say it but to hit that spark plug like that its got to be a broken cylinder
ilir14 is offline   Reply With Quote
Old 10-26-2016, 12:19 PM   #3
ABMLS3
ABMLS3's Avatar
Did you read everything I wrote? Piston didn't hit the spark plug, ceramic part is cracked and I'm holding it upside down which is making the ceramic fall and touch the ground part
416 C.I ,TH400
Old 10-26-2016, 04:02 PM   #4
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Go pick up a fuel injector tester from any auto parts store and start checking them. You can also leave the car idling and disconnect each injector one at a time, listen for idle change. That will tell you if they are pulsing also.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
