03-15-2015, 10:30 PM | #1 |
Drives: 2010 Camaro 2SS/RS Join Date: Apr 2010
Hidden hitch.
Good evening everyone. I have looked at the Hidden hitch used for towing.
I am not planning on towing but am thinking of installing one for a rear tow point for track days. Seems the central mounting position is desirable and when the receiver (with a tow point on it) would work pretty well. There is a weight penalty but is easy to do and remove in the future if I sell the car.
2010 2SS/RS L99 CAI intake Stainless Works headers and Hi-flow cats CORSA cat back exhaust livernois motorsports dyno tune VMAX throttle body ELITE catch can GM clean side catch can 2014 lca BMR rear toe links PEDDERS Supercar suspension PEDDERS poly subframe bushings JPSS BLACK MAGIC rear sway bar DSS 1000 hp axles 1LE wheels Michelin 285/35 tires CTS-V front brake upgrade fuel rail flip heater hose relocation
03-27-2015, 07:01 AM | #2 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
the hidden hitch should work.
you might consider a hard rear tow point, it will be about the same money, weigh less and not hang down below diffuser. the strap idea is very cheap and light..........another good idea http://www.camaro5.com/forums/showthread.php?t=329205 http://www.camaro5.com/forums/showthread.php?t=364406 Edit: another option http://www.camaro5.com/forums/showthread.php?t=369382
03-28-2015, 08:51 PM | #3 |
Thanks for the info h018871. I think I will go with the strap idea. Seems to be the least noticeable when not needed.
