05-11-2014, 10:43 AM | #1 |
Drives: 2016 2SS Camaro Join Date: Apr 2014
Best tire shine?
I normally use the foam spray can stuff and let it dry but I'm wondering if there'd some thing out there that doesn't sling and will hold up over time. I don't drive my car in the rain so that's not a real concern for me
05-11-2014, 11:15 AM | #2 | |
Drives: 2011 RJT/RS Join Date: Jan 2013
05-11-2014, 11:36 AM | #3 | |
Drives: 2013 2LS BLK Join Date: Oct 2013
SCG pro like of tire shine won't sling but will probably be less durable. Poorboys natural look is the cheapest and won't sling, but is the least durable.
05-11-2014, 11:43 AM | #4 | |
Drives: FOR SALE! Bumblebee 1 of 1 Join Date: May 2010
Make sure you take care applying it or tape off rims and fender lips. Also make sure tires are clean - don't drive until completely dry. Feels like clear rubber when done. |
05-11-2014, 01:50 PM | #5 |
Spam Nick@Adams inbox until he releases Black Out.
Until then, the best I've found is Ultima Tire and Trim Guard Plus Sent from my HTC One using Tapatalk
[B]
05-11-2014, 02:04 PM | #6 |
Successfully spammed.
05-11-2014, 04:58 PM | #7 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
It depends on your definition of shine. CG VRP works very well to give your tires that dark clean look, but it's not shiny like some want. It holds up very well over time as well. I've noted my tires beading water a couple weeks after use. It works well on all vinyl, rubber, and plastic trims.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
05-11-2014, 06:22 PM | #8 |
Smoke Alotapotomous
Drives: 2010 Camaro SS Join Date: Jun 2011
I like Carpro PERL.
2010 Camaro TT SS. AGP twin Turbo
05-11-2014, 07:48 PM | #9 |
I like teeth.
Drives: #198 Join Date: Oct 2009
I'm a fan of Carpro PERL as well. Best look with no sling imo.
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517 "When you want to succeed as bad as you want to breathe, then you will be successful." |
05-11-2014, 08:32 PM | #10 |
Drives: 221SS1LE Join Date: Oct 2008
I use Meguiar's spray gel which gives a fantastic wet look to the tires,it just sucks that it slings off even after being left to dry overnight.I know it's off the counter stuff and shouldn't expect more of it,but damn after all that work it sucks because my truck is white.
05-11-2014, 08:43 PM | #11 |
Drives: GM Join Date: Sep 2010
Meguira's insane tire has a nice wet look.
Roto- Fab Cai, SLP 1 3/4" headers, 3"X pipe, LM2 cat back, Comp Cam & AI Heads, SLP UP, RPM Tuned, GPI Intake, Vmax TB, ADM Air Scoop, 3.91 Gears, Gforce driveshaft, Braille 21#, Elite Catch Can, Pfadt Tie Rods, Diff Bushings and Trailing arms, Eibach spings & sways, BMR cradle bushings, Nt555r's.
05-12-2014, 11:56 AM | #12 |
Drives: The shiny ones. Join Date: Mar 2010
Thank you everyone for the spam.
OP, I sent you a PM. |
05-16-2014, 05:47 PM | #13 |
Wanna say thanks to nick at Adams for hooking me up with some products :shake: even threw in two mints lol
05-16-2014, 06:46 PM | #14 |
Good stuff! My choice as well.
Laus Deo
