09-19-2013, 05:27 AM | #1 |
Alternative to Clay Lubricant?
I've used clay, and it works great. I just don't like having to buy a "brand name" clay lubricant. Anyone have any home made suggestions using common household items?
09-19-2013, 05:40 AM | #2 |
Participating in my own thread...lol...just read somewhere that Optimum No Rinse (ONR) car wash (not sure of the mix ratio) mixed with water in a spray bottle does wonders. Since the recommended amount of ONR to actually wash your car is 2oz to 2 gallons...I imagine only a small amount is needed.
09-19-2013, 05:47 AM | #3 |
Drives: 2011 Camaro SS, 2012 Shelby GT500 Join Date: Jan 2013
I've used Zaino products for years and won't change. I use their clay bar and higher concentration of car wash and water.
Sent from my iPad using Tapatalk HD |
09-19-2013, 07:29 AM | #4 |
Drives: 2012 AGM SS Join Date: Jun 2012
ONR or Ultima Waterless Wash costs pennies and works great. I believe ONR is actually 1oz to 2 gallons of water for car washing and 2 oz for clay lube.
09-19-2013, 07:36 AM | #5 |
Drives: 2017 Camaro ZL1 Join Date: Nov 2006
I just use a mix of car wash soap and water, works great. You just need something to lubricate the surface so the clay won't stick as you rub it on the surface. Soapy water does the trick.
09-19-2013, 07:51 AM | #6 |
You don't need anything special. Any quick detailer works just fine.
09-19-2013, 11:40 AM | #7 | |
Sent from my HTC One using Tapatalk 2
[B]
09-19-2013, 11:48 AM | #8 |
Drives: 2021 1LE Join Date: Jul 2011
I like Gary Dean's Infinite Use Detail Juice.... sue me. I have also been know to use the speed towel with soap after my wash.
09-19-2013, 01:31 PM | #9 |
ICANHAZ
i use Gary Deans IUDJ as well with no issues. His soap on the other hand just not that good.
09-19-2013, 04:33 PM | #10 |
Drives: 2022 ZL1 Join Date: Aug 2013
I usually just use whatever quick detailer I have at the time.
09-19-2013, 10:32 PM | #11 |
Exactly. No need to order anything special to lube your clay bar.
09-20-2013, 03:17 PM | #12 |
That's a very expensive way to go
[B]
09-20-2013, 04:17 PM | #13 |
Why do you say that? I've used quick detailer many times as a clay lube with no issues whatsoever.
09-20-2013, 05:01 PM | #14 | |
There's nothing wrong with it, it's just a costly option. Sent from my HTC One using Tapatalk 2
[B]
