Old 12-09-2018, 07:17 AM   #1
chuckclanton
Drives: 2021 Camaro 2LT
V6/A6 combo LSD issue.
As this engine/trans combo has no LSD, what is the impact of going to a
stiffer rear sway bar? Improves or makes the traction issues worse?
The understeer can be corrected with a square setup, right? So...…..?
chuckclanton is offline   Reply With Quote
Old 12-09-2018, 08:39 PM   #2
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
It certainly won't hurt. A square setup will still have some understeer with the stock bars.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 12-10-2018, 12:04 AM   #3
Army of Wuzzy
Army of Wuzzy's Avatar
Drives: 2011 Chevrolet Camaro LS
I have front and rear BMR sway bars on my v6/m6 and it improved the handling exponentially. I believe the a6 has a different setup but either way it is definitely worth the effort. They're also easy to put in, even on just jack stands. I run a square setup as well and I have little to none understeer. if you have any questions, feel free to DM me as I might be able to help you.
"If you aren't first, you're last"
-Ricky Bobby
Army of Wuzzy is offline   Reply With Quote
Old 12-10-2018, 07:09 AM   #4
chuckclanton
You have a LSD I don't. If you get loose the power goes to the wheel with traction, my open diff continues with 50/50 power split. Its not clear to me
how much more sway bar I can add to the rear. I need to keep both rear tires
planted. Also any concerns regarding the rear caliper bolt hitting the rear bar as the rear breaks ware?
Old 12-10-2018, 08:10 AM   #5
chuckclanton
Me again. On the BMR setup are links supplied and if so any drilling needed due to link diameter vs mounting points. Im thinking with a open diff maybe the bigger bars are the way to go until excessive slip angle becomes a problem.
