Old 12-21-2018, 08:28 AM   #1
chuckclanton
Drives: 2021 Camaro 2LT
How good are FE2/V6 shocks?
So....My 2015 2LT/RS now has 20x9s on front as well as the rear. 65 lbs each
. I have a new set of Pedders lowering springs in the garage(like the spring
rates). Can the stock shocks deal with all this unsprung weight and lowering?
If not will FE4/SS shocks fix the issue? B6s to expensive, Koni Orange has issues.
Maybe Pedders Sport-Ryders?
chuckclanton is offline   Reply With Quote
Old 12-21-2018, 08:45 AM   #2
Avenging Orange
Avenging Orange's Avatar
FE4 are an improvement. What I'm going to use when I lower.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 12-22-2018, 09:03 AM   #3
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Go with the 1LE shocks/struts and don't look back.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 12-22-2018, 05:36 PM   #4
chuckclanton
Are the 1LE struts a directreplacement for the fe3 struts? Seems the shaft is bigger in diameter as it calls for a different strut mt nut Also are the fe3 front sway bar links ok for the switch? Any other parts I may need other than the struts and strut mount nut??
Old 12-22-2018, 07:19 PM   #5
LCPLPunk
USA-1
LCPLPunk's Avatar
I put the 1LE front/rear setup on my 2010 and it bolted right up. When I put the 2012 ZL1 rear sway bar on I had to get new LCAs and end links in the back, but didn't have any issues.
Old 12-22-2018, 07:26 PM   #6
chuckclanton
Wont use the rear shocks. They are over $200 each! and they you need the top mounts. Probably go with Koni Str rears.
Old 12-22-2018, 09:31 PM   #7
LCPLPunk
USA-1
LCPLPunk's Avatar
No need for top mounts. I found a deal on mine, a guy was selling the fronts and rears for $200 shipped.
Old 12-23-2018, 07:12 AM   #8
chuckclanton
Ive been looking. Seems new is the way for the fronts. The Delco P/N
for the rears is $187 each.
Old 12-23-2018, 08:29 AM   #9
LCPLPunk
USA-1
LCPLPunk's Avatar
https://www.camaro5.com/forums/showthread.php?t=538464
Old 12-23-2018, 08:46 AM   #10
chuckclanton
So you installed the rear shocks with your existing upper shock mount instead of the called for 1LE rear mount?
Old 12-23-2018, 01:26 PM   #11
LCPLPunk
USA-1
LCPLPunk's Avatar
Sure did. I didn't want to spend the extra coin on the 1LE setup and I read on these forums that the cost really wasn't worth it. I did a High performance driving education day with my setup and had no issues.
Old 12-23-2018, 01:36 PM   #12
chuckclanton
So it a performance thing , not a fit thing?
Old 12-23-2018, 01:53 PM   #13
LCPLPunk
USA-1
LCPLPunk's Avatar
Yep. I thought the same thing too but thankfully it was just a performance thing.
Old 12-26-2018, 11:15 AM   #14
chuckclanton
Looking further into the 1LE shocks(1LE Forum), a lot of bad press on the
reliability and/or valving for the street! So it looks like FE4 struts or maybe
Pedders Sport Ryders
