11-21-2015, 05:43 PM | #1 |
Drives: 2013 ZL1 Join Date: Nov 2013
I know another Cam question
I am debating two cams the Brian Tooley stage 1 or 2.
My mods are as follows: Kooks long tubes, no cats Rotofab CAI ID850s ATI Lower with 18% pulley Just curious what the performance gain would be between the two cams? Really do not want alott of Lope from a Cam. Also do not want a cam that is hard on the valve train and has a really hard ramp rate. Looking for long term durability. Just seeking info on these two cams? Thanks, Rob |
11-21-2015, 06:42 PM | #2 |
Drives: 2013 ZL1 Join Date: Jan 2015
Get the milder cam, gains with out ported heads will be similar and if you want a milder idle then there's your answer.
2013 A6 ZL1
11-21-2015, 07:23 PM | #3 |
Drives: '21 ZLE A10 Join Date: May 2012
BTR stage 2 is a great cam for mild lope and big power!
11-22-2015, 12:30 AM | #4 |
ZL1 Pilot
I just did the stage 1. Along with a 9.55 lower. Omg does it run. I too didnt want something that would beat the crap out of the valve train. I also did the CHE modified rockers for bulletproofness. The cam is not too lopey. But there is enough to tell its cammed. It's just right. Makes roughly the same power as the 2
GP Tuning 2.5 Cam, RPS Carbon Twin Clutch, Ported Blower, Kook's Headers, Cold Air Inductions CAI, ID850's, 9.17 Lower, 2.5 Upper, JMS BAP, Pedders Front Radius Arm Inserts, Whiteline Subframe Inserts, Tuned by me with HP Tuners Idle Clip Link...........https://www.youtube.com/watch?v=gTL8S9eHwbs |
11-22-2015, 10:17 AM | #5 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Skip the 1 and 2 and go to the stage 3. It is also ground on the LSL and XER lobe profiles like the 1 and 2, and is just as easy on the valvetrain. And makes big power. It has a noticeable lope but still mild because of the 0 deg overlap. Call Brian Tooley and discuss with him. He has told me he rarely sells the 1 and 2 anymore and everyone usually goes with the 3. And get all the springs and matching parts from him also and you will be trouble free.
Bryan 2018 ZL1 M6
11-22-2015, 10:47 AM | #6 | |
ANGRY Z
Drives: 2015 Camaro ZL1 Join Date: May 2012
2015 ZL1 A6 396 stroker RWHP- depends on nitrous
11-22-2015, 11:21 AM | #7 |
I know the Stage 3 is a nice cam but for me the Lope will be undesireable. This will be my wife's daily driver and I have to careful. I am just trying to decide between the stage 1 and 2.... If there is not a huge power loss between the two the stage 1 will probably be my choice. Just curious what else is people doing to increase valve train durability?
11-22-2015, 11:35 AM | #8 |
ZL1 Pilot
If you dont like the lope of the 3. You probably wont like the 1 or 2. A guy in our club had the 3. Compared to mine, there's not that much difference in the lope. If that's your determining factor then you should go with a custom grind and let them know you don't want lopey. Rather than just buying one off the shelf. There are certain tradeoffs for power. All depends on what you're going to do with the car i guess. If you're happy with the current power and performance, leave the cam alone.
11-22-2015, 12:06 PM | #9 |
ANGRY Z
If you want some upgrade but "stock sounding" have you considered the LS9 cam??
11-22-2015, 12:23 PM | #10 |
My gt9 cam is quiet and drives like stock
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80 “1360 Rwhp 1225 Rwtq 25 lbs of boost” |
11-22-2015, 12:40 PM | #11 |
+1
2013 A6 ZL1
11-22-2015, 05:21 PM | #12 |
And built on LSK lobes and very tough on the valvetrain.
Bryan 2018 ZL1 M6
12-05-2015, 05:53 AM | #13 |
Drives: 2014 Camaro Zl1 Tripple Black! Join Date: Nov 2014
12-05-2015, 07:44 AM | #14 | |
Ted.
www.jannettyracing.com
