09-11-2014, 02:42 PM | #1 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
Who has blown up the motor in your FI camaro or any gm Ls vehicle?
Just curious. People constantly ask how much boost will it hold, how much power will it hold blah blah. List what kind of forced induction, how much boost, other mods and what let go. Should be intersesting.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
09-11-2014, 03:10 PM | #2 |
Guest
Maggie SC @11-12 psi, Night Fury cam, Alky ctrls Dual nozzle Meth, LPE twin fuel pump, ID850 inj, Super Chiller (IAT's never got over 100F) Kooks LT totaling 650rwhp with a 6L80 auto. 22,000 miles on engine, about 1000 at this power level with six 1/4 mile passes. What let go? Good question my builder said no one could answer that after they took my engine down.
09-11-2014, 03:27 PM | #3 |
Engine builder couldnt find out what broke? Huh?
09-11-2014, 04:25 PM | #4 |
Stock engines break all the time, so where do you put those? There will be people making 900+ for years, and others popping them at idle on the way home. Friends zl1 blew up at a stop light on the way home from a car show. Another friends corvette was bone stock and lost a motor.
Good combo, good tuner, and good octane and a FI LS motor can live a long life assuming no factory defects/etc. You will always have people popping at lower levels than others like the guy above.
Nick
Corvette Z06 -1200ish rwhp |
09-11-2014, 04:49 PM | #5 |
Drives: 2010 Camaro SS Join Date: Feb 2010
Fuel pressure dropped off at 191 mph at the Texas mile-Detonated-bent five rods.
Drove it home 800 Miles.
LSX 429, Vortech V7 YSI, Squash Fuel system, Jannetty Tuned.
09-11-2014, 04:56 PM | #6 |
Drives: Maggie blown LS3 vette Join Date: Aug 2009
09-11-2014, 05:06 PM | #7 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
My OE motor lasted about 6500 miles at powers from stock, 440whp, 637 whp and 715whp at 11 psi.
I was running an experiment on how much abuse the motor could take before letting go. My last mod with the D1 was pulleying down and boost at 11psi. This was 715rwhp with meth. My tuner at the time told me that even though the injector DC was 88%, the meth would cover it. My bad for trusting him. Well, 6 weeks later at that boost and about 6 gallons of meth the # 5 piston top 2 ringlands went. Car drove but smoked pretty good after that when in boost. I just depends! If you drive it very abusively, its gonna go. If you baby it, it will last years at over 800. Stuff happens! My new motor seems to be way more robust btw
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
09-11-2014, 05:34 PM | #8 |
Drives: 2013 SS Join Date: May 2013
My stock bottomend 6.2L (truck) lasted 10k miles @ 13lbs with a T76mm
Forged 376ci lasted 30miles yes 30 miles @ 20lbs with a 76mm smh....... forged 390 lasted 2,000 miles before I sold. My 6.2L made 627rwhp the forged made 737rwhp and the 390ci made 817rwhp and my stock 6L80e with a 3200 converter never skipped a beat
09-11-2014, 06:12 PM | #9 |
I didn't know the rods were bent or I probably wouldn't have driven it back.
The bent rods cocked the pistons in the bores and scored them up a bit. It didn't smoke or use any significant amount of oil. I sold the stock shortblock to the local machine shop and built the LSX. It is pretty amazing the abuse they will take.
09-11-2014, 06:30 PM | #10 |
A tad over 10k miles now on my Livernois build LSX motor living its life between 15-22psi, and 800-1100rwhp. No issues, runs and drives great. Stock motor broke a lifter at 23k miles, but that isn't related to FI. It did have a blower and was 705rwhp at the time. Pistons looked great, no issues. Stock cars and trucks eat lifters all the time so do you put that down as a forced induction motor failure?
Nick
09-11-2014, 06:39 PM | #11 |
Drives: 2011 Camaro SS/RS Join Date: Dec 2010
ill be going with a new forged ls3 and twin s256 turbos, 4l80e, fore fuel system (e85), custom cam shaft etc.. hope to have it live a long life since i dont do much drag racing or road coarse
2011 SS/RS @ home 12/28/2010
09-11-2014, 06:59 PM | #12 | |
09-12-2014, 12:03 AM | #13 |
Keep it coming
09-12-2014, 01:57 AM | #14 |
Mine lasted 3 months before cats blocked up & detonated all over the place, wish I had read forums on this before it happen, expensive upgrade, wife never did get that new kitchen upgrade.
Camaro 2SS/RS 2010 / L99 / Whipple SC /Dynatech Headers & Catts (gutted), ID 850 injectors, ZL1 fuel pump +BAP & ADM pump controller, ZR1 3Bar MAP, Dual Elite Catch Cans, 91 octane ,Eibach sway bar kit , Driveshaft loop, oil cooler delete, ADM dual gauges (AFR/Boost) LC1 wideband controller, D/D, ARP stud kit ,Callies forged slayer crank 3.622", callies ultra rods, wiseco forged pistons, L99-LS3, rollmaster double row steel timing set & comps cam timing cover,blower cam 630/660 lift,3/8 pushrods, pac gear 8deg, yella terra ultra lites. LS9 head gaskets. Texas speed custom oil pump. Asm by me.
