Old 05-14-2015, 09:53 AM   #1
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
391 gears and warranty
Hey I was wondering has anyone found out about the small print on installing the 391 gears? I know it states will not void warranty , but does the dealer need to supply the parts and/or do the labour or can we just bring the car for a recalibration of tach? sounds like a real great mod for the under 550 hp cars
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
Bretts is offline   Reply With Quote
Old 05-14-2015, 12:59 PM   #2
Merc
In The Circle
Merc's Avatar
I believe the kit from GM performance has the voucher to have ECM changed for 391 gears. Not sure if you can do the gears yourself and then take to Dealer for recalibration. I can tell you it's a whole brand new car with the gear change especially if it's a M6.
Old 05-14-2015, 01:31 PM   #3
Meltdownaverted
I sell Camaro's
Drives: traded 11 2SS RS SGM for 13 SS 1LE
Gotta go through GMPP and the dealerships to work with the warranty
Meltdownaverted is offline   Reply With Quote
Old 05-14-2015, 06:42 PM   #4
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
ok thanks ! I have a line on a set of gears from one of our wccc members but they are new gm parts to be sold to me would that be still ok ? m6 it is
