01-18-2014, 03:03 PM | #1 |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
How wide is good enough Damn.
Ok so I successfully fit the 19x10.5 TSW Nurburgring rim with 305 30 19" Bridgestone RE-11 up front with my Bilstein PSS10s and 8" ,2.5" internal diameter 450lbs Eibach spring . Now the 305 30 19 Yokohama AD08R shows up with 1.3" wider thread width and now I want to fit that up front. The AD08R on the 10.5" rim is not going to be a tight fit like the RE-11s. It will however fit the Z28 rims perfectly but they aren't available for sale to non Z28 owners, bummer. RE-11 actual real world threadwidth is like 10.4" , Yokohama AD08R is literally 11.7" no freaking joke , way wider foot print over the RE11. Figure I would be happy with the RE-11s at all 4 corners but no , I've got the need , the urge to fit the AD08Rs up front as well. 1LE / Zl1 285 front tire is like 9.5" thread width.
01-19-2014, 10:53 AM | #2 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Forgestar 20 x 11's, in your choice of offset? Even 20 x 12's are available, although that's a slight stretch beyond what either of these 305/30's are supposed to be fit to. I couldn't tell you who to go through that would know what offsets the Camaro in general or yours in particular would need.
What I am seeing for the tires is 11.6" tread width at Tire Rack and 11.8" at Yokohama for the AD08R and 11.1" at Tire Rack for the RE-11. Both tires are 12.2" section width on 11" wide wheels, and are both approved for 10.5" - 11.5" wheels. That the section width is the same means that tire to strut clearance won't be any different. The 0.6-ish tread width difference (I'm using the "average" of the above two numbers) becomes 0.3" wider per side, so I doubt that sheetmetal clearance is going to suddenly become an issue if it isn't already. I could put together a rough comparative plot of any combination of these wheels and tire sizes if you think it would help any. Norm |
01-19-2014, 12:51 PM | #3 | |
01-19-2014, 05:06 PM | #4 |
So you're telling me that the Pss10's perch is right at to barely above a 305/30-19 RE-11 tire's unloaded radius and close enough that a dimensionally slightly taller tire with squarer shoulders will hit?
Norm |
01-19-2014, 06:10 PM | #5 |
I'll take pictures and show you. I gotta get off my lazy ass and post those pictures. Sorry this NE cold weather and snow got me lazy is heck. Both tires are the same height just that with the wider threadwidth and square shoulder of the Yokohama there will be perch rubbing issues. The perch is actually on the same level as the last 1/4" of the top of the tires. The round shouldered RE-11 makes it work where as the Yok will hit. I also have camber plates that can be set to a more performance camber to give more clearance.
01-19-2014, 10:51 PM | #6 |
A few pictures showing my front 19x10.5" setup. Actually looks much better in real life. The Nissan GTR in the picture is equipped with 18x10.5" but this is what the wheels would look like with the Yokohamas on them instead of the Bridgestone RE-11s. Pictures with the ruler is the RE-11 top and AD08 under it, clearly shows how much wider the threadwidth of the AD08R is over the RE-11.
01-20-2014, 07:24 AM | #7 | |
Thanks for the pictures. Truth be told, I'd always prefer to put 295/35's on 11's or 11.5's anyway. 10.5's are for those little 285/35 sizes that's about all I can reasonably fit on my car without needing staggered-offset wheels Norm |
01-20-2014, 10:16 AM | #8 | |
01-20-2014, 08:50 PM | #9 |
Thanks. L99, I'll have to take a peek over there in addition to Terry Fair's Vorshlag and Sam Strano's Stranoparts sites. More options are always good to be able to choose from.
Norm |
09-02-2014, 06:14 AM | #10 |
Drives: '16 C7 Z51 Join Date: May 2012
I'm trying to find an affordable yet very light set of wheels for my 1LE for track duty. I was thinking about going with these wheels (19x10.5 Nurburgrings). I will be using them along with coilovers, and either 295/30 or 305/30 R888 tires. Would you recommend this setup? Would it easily work, or would it be a headache? If it's going to be too close, I don't think it would be appropriate for track duty :(
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD Last edited by X25; 09-02-2014 at 09:53 PM. |
09-02-2014, 09:53 PM | #11 | |
09-02-2014, 10:48 PM | #12 | |
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD Last edited by X25; 09-03-2014 at 12:53 AM. |
09-03-2014, 06:31 AM | #13 |
Well bud, not any tire. For example you won't be able to run a 335 F know what I mean. But you should be able to fit that R888 up front. I honestly would also consider the CCW 18" wheel setup. Sticks out but use them for track only and be done.
09-12-2014, 07:01 PM | #14 |
Drives: 2014 1SS Join Date: May 2014
do you have any more pics? Love big r-compound tires on these cars.
