01-21-2013, 07:10 PM | #43 | |
Drives: SILVER Join Date: Dec 2010
Posted from Camaro5.com App for Android |
01-21-2013, 07:17 PM | #44 |
Wifey Lover
Drives: 2013 Crystal Red 2LT/RS Join Date: Nov 2011
Did you receive your complimentary bottle of lube with that job?
01-21-2013, 07:21 PM | #45 |
Same thing happened with me... Almost 400 bucks, But wait it gets better, after they change the brakes they didn't put on the upgraded brake pads to the brembo brake pads that I have on ss. i had squealing occurred two days later. i have to go back to the shop ,still did not have a right brake pads for the car and it sits in the shop for two days. talk about a rip off
01-23-2013, 05:45 PM | #46 |
Drives: 2013 1LT RS CRT Join Date: Jan 2013
retail on the OEM brake pads is $246.40(that is the retail price for the new updated pads per the bulletin).we(a chevy dealership) had a customer come in and decided to go with the cheaper Durastop (ceramic) pads and they didn't make it down the road before they started to squeal like a pig.the customer came back and we installed the OEM pads and the problem went away.
i agree with Spektrum,it is both the dealerships fault for not providing an estimate,but also the customers for not asking for one. we have sportscars,not everything is cheap on them.for 2013 the camaro has a heavy duty set of frt pads for $450.00.i would presume they are for the ZL1,but my parts catalog is not specific on that. |
01-23-2013, 07:16 PM | #47 |
Drives: 2010 Camaro 2LT RS Join Date: Sep 2012
Oem parts usually are not necessary but are always overpriced.
If you're not living on the edge, you're taking up too much space.
01-23-2013, 07:32 PM | #48 |
I only go to the dealer for parts when I cannot get them elsewhere. The parts store by me has a lifetime guarantee on most parts. And front pads are perhaps "auto repair 101". But I can still understand why not everyone will attempt the DIY.
Camaro5 is a great resource if anyone wants to give it a shot though. I already bought a new 150 ft-lbs torque wrench for the lug nuts. At 26K my DIY has been limited to oil changes. |
01-23-2013, 07:39 PM | #49 |
Drives: 2013 RS - 2013 2SS/RS - 1971 RS Join Date: Sep 2012
01-23-2013, 08:13 PM | #50 |
Drives: 2013 2SS/RS/1LE Join Date: Apr 2010
What was the complete parts list? They should have also replaced the rotors, or at least turned them.
And it doesn't take long to rack up a large bill with the hourly shop rate at $100 hr. |
01-23-2013, 08:16 PM | #51 |
INJACC
Drives: 2010 CGM 2LT/RS AUTO Join Date: Jan 2009
They were charging me $350 Cdn :(
Member of 'Club Elite' #70
2LT/RS Auto / Solo HFC / Solo Mach X-LLT J-Pipe / JBA Headers Shorty CAI - Cold Air Inductions / VMAX TB / Trifecta Tune Hotchkis Max Strut Brace / Blade Dovetail Spoiler / Elite Catch Can ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / ACS T1 Led Light Kit ACS Rockers / ACS Composite Hood Liner / ACS Upper Rear Quarter Ports ACS Front Wheel Mud Flaps / ACS Rear Wheel Mud Flaps / Vitesse Throttle Controller Pedders Drop Suspension / BMR Lower Control Arms / Style 41 ZL1 Wheels / Oracle Afterburners / Oracle Concept SMD Side markers Complete SS Brembo Brakes Set |
01-23-2013, 08:54 PM | #52 |
Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
If they took the rotors off, they should have replaced the caliper bolts as well. Those are one time use bolts if they followed the specs. Those are at least $20 discounted for a set of four.
01-23-2013, 08:58 PM | #53 | |
I Got My Orange Crush
Drives: it like I stoles it... Join Date: Jan 2011
Received my Hawk Ceramics for all 4 corners today from Amazon for less than $200.
My love is in league with the freeway. Its passion will ride, as the cities fly by, and the tail-lights dissolve in the coming of night. And the questions in thousands take flight ~Robert Plant - Big Log~ |
01-23-2013, 09:27 PM | #54 |
KaBoom1701
01-24-2013, 07:32 AM | #55 | |
Look at it this way,Take a 2012 Corvette.If the fuel pump dies and you can get a GM one for $600 or an aftermarket for $200.00.The dealership wants 4 hours of labor @ $100.00 per hour.That's a $1000.00 for the repair at the dealer.Or $200.00 for you on your garage floor.Sounds like a no-brainer to me.Both fuel pumps come with a lifetime warranty. Now your aftermarket pump dies in 8 months,no problem..you have a warranty.Now the problem becomes,the Pep Boys pump doesn't cover labor.So you spend another weekend taking out the rear end,transmission,exhaust and torque tube of the vette...on your garage floor to get even close to the tank with the primary pump in it,so it takes you 8 hours each day on your garage floor to replace it. Let's do the math.... Dealer- pump $600.00 labor $400.00 total $1000.00 with a lifetime warranty on the parts AND labor.So,if the GM pump fails,just drop off your car and we'll take care of it for you. Aftermarket- pump $200.00 labor $your time(@$100.00 per hour) x 16 hours $1600.00 (8 hours a day x2 days on your garage floor without a lift) total $1800.00 now if it fails ever again(and it will...) you have all that labor to do all over again...so $1800.00 plus another $1600.00( for another lost weekend).... not all aftermarket parts are a deal...... |
01-24-2013, 07:54 AM | #56 | |
Drives: 13 2SS/RSvert,CRT,dual-mode exhaust Join Date: Apr 2012
Your math is correct...your assumption that non-OEM parts are somehow lacking when compared to OEM parts is flawed.
