Old 02-19-2015, 04:51 AM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
Just ordered my custom Pat G Cam Motion Cam
dont know if its taboo to post the specs so i wont.
I am replacing a Comp Cam that whines so will i have to replace the crank balancer seal again? I also have a Melling High flow oil pump with the high pressure spring in it. should i put the stock pressure spring in it.
JCunningham is offline   Reply With Quote
Old 02-19-2015, 02:17 PM   #2
Bill@RaceProvenMotorsports
Bill@RaceProvenMotorsports's Avatar
Drives: 09 G8 GT
"A Comp Cam that whines"? What does that mean?
Bill@RaceProvenMotorsports is offline   Reply With Quote
Old 02-19-2015, 02:21 PM   #3
62nalide
62nalide's Avatar
Drives: 2013 SS
I've been rocking my comp cam for over a year still good over here
62nalide is offline   Reply With Quote
Old 02-19-2015, 02:23 PM   #4
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Good for you man! I went the same route.
They are your cam specs to do as you please with. I post my Pat G specs all over...LOL
226/232 112+4...she be choppin too!!!
Love my Pat G cam. Who are you having grind it for you? I went with Pat G's recommended guy out of Lafayette, and was VERY happy. Those cam motion cores are a thing of beauty man!
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 02-19-2015, 03:52 PM   #5
1989GTA
Drives: 1989 GTA Trans Am
I also bought a Patrick G camshaft (Cam Motion) and there was nothing said about hiding the specifications. I have posted them as well. I think the key is the profile of the camshaft lobes.
1989GTA is offline   Reply With Quote
Old 02-19-2015, 04:28 PM   #6
Ajdin@A2BMotorsport
Drives: 2013 Camaro 1SS/1LE
Running a Comp in mine, with 60+ passes and 2 Track days no problems so far.
Ajdin@A2BMotorsport is offline   Reply With Quote
Old 02-19-2015, 05:38 PM   #7
Bo White
Bo White's Avatar
A few of the comp grinds have been a touch rough and cause a whining sound.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 02-19-2015, 05:44 PM   #8
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
You heard it hear;
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 02-19-2015, 07:21 PM   #9
DrkPhx
DrkPhx's Avatar
^^^ Damn. That's bad. Does it do that all of the time?
Old 02-20-2015, 06:48 AM   #10
JCunningham
Drives: 2017 2SS M6
Comp did a shitty job of polishing there lobes. Yes Its a Cam Motion. forgot to mention that.
specs 226/230 .626 .626 113+4
Old 02-21-2015, 01:33 AM   #11
JCunningham
Drives: 2017 2SS M6
it dose it at higher rpms sounds like a supercharger.
Old 02-21-2015, 07:50 AM   #12
Schluney
Schluney's Avatar
Drives: 2014 2SS 1LE
I just had Pat G spec me a cam to go with my trick flow 255 heads! Should be ordering the cam this week specs are 228/234 .626 .626 113 +2
14 2SS RS 1LE Recaro NPP Pat G cam and tune, Trick flow heads Long tube headers catless
Schluney is offline   Reply With Quote
Old 02-24-2015, 05:26 AM   #13
ksmrz
ksmrz's Avatar
Drives: 2010 Camaro
Yes you should probably replace it. Cheap insurance and the timing cover has to come off anyways. Who's cam did you have. I have had a comp cam from jannetty that had zero issues. Now running a night fury on a comp core. Hope it stays quiet lol cause that's just a pain in the ass I think most people would rather do once for work. Hopefully comp or your cam vendor gives your money back or stands behind it. Comp has been around much longer than I have and find it hard to believe that they would send out shitty cams but as I've come to learn nothing is impossible
2010 2SS LS3 228/235 Cam Motion custom ground cam, AI 280cc ported heads, Dynatech 1 7/8" long tubes, catless mids, CAI intake, ATI 10% UDP, CORSA cat back, Slp 160 tstat, gm 3.91s/Tru trac, EFI LIVE tuned by myself
ksmrz is offline   Reply With Quote
Old 02-24-2015, 05:30 AM   #14
JCunningham
Drives: 2017 2SS M6
yep anything is possible. comp offered to repolish it. but nothing else. Kip from, CM offered to polish it to for free.
