12-18-2009, 08:42 PM | #1 |
VETT 4 5
Drives: Yellow 1SS/RS w/ Clutch Join Date: Nov 2009
Burnout - clutch instead of tires ?
Now that I've got nearly 1,000 miles I thought I'd finally do a real burnout. I dropped the clutch about 4 - 5000 RPM and *thought* the tires were spinning, but the clutch pedal itself didn't seem to have engaged properly and clutch fumes filled the car for the next 10 miles.
Anybody with similar experience ? Anybody had any luck with the dealer fixing a clutch under warranty ? Clearly a bone stock car should have a clutch to handle this. |
12-18-2009, 08:48 PM | #2 |
Drives: '10 CGM 2SS/RS 6M Join Date: Oct 2009
Yes, believe it or not, I had the same problem! That shit was pretty embarrasing. First and last burnout that i attempted. Clutch still works good though, I thought I would never get the smell out of the car. The clutch seemed to stay halfway not fully released then came the smoke and the engine started sputtering.
12-18-2009, 08:53 PM | #3 |
So-Cal Race team!!
Drives: Tahoe LTZ,2010 2SS/M6 Camaro Join Date: Apr 2009
Turn off the traction control and get this..This was my first attempt.
WE RACE DEEP!!
BBK Intake, Flowmaster AT cat back Barton shifter,Painted stripes,,Heritage grill,LED DRLs, Smokin Tires!! |
12-18-2009, 09:27 PM | #4 |
Drives: Black 2SS/RS Silver Hood/Hockey Join Date: Nov 2009
Check ur brake fluid. Others have complain about the clutch getting stuck halfway up also i personally haven't had the problem though. 1350 miles on mine.
2SS/RS M6,Polished wheels,Silver rally/hockey stripes.
12-18-2009, 10:10 PM | #5 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
It doesn't take nearly that many rpm's to break'em loose and do a burn out, and yes you must turn off traction control!
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
12-18-2009, 10:37 PM | #6 |
Drives: 10 Camaro/69 Bronco/08 Mazda3 Join Date: Jul 2009
Takes me 4000 and I still bog down to about 1500.. I am at 6000 msl so I have a power disadvantage, but the gears and the 20" just kills it. Get rear end gears and it will wake this thing up and save your clutch...
Selection Worksheet - 04/27/09
3300 - 08/03/09 6000 - 08/25/09 VIN# 34612 Bitchin Camaro - Dead Milkmen - http://www.newgrounds.com/portal/view/8092 Thank You Oshawa - Domo arigato Mr. Roboto ~1600 mi so far - 07/18/10 |
12-19-2009, 12:04 AM | #7 |
VETT 4 5
Thought I had traction control off - double-click to Competition mode. I hadn't read the manual though - just going off the new car once-over. I suspected something weird there. So now I'll RTFM........<blush>
...and yes it was pretty embarrassing. Motor didn't bog though - cranked right through the clutch and any traction control..... |
12-19-2009, 08:56 AM | #8 |
Tampa Gulf Coast Family
Drives: 1977 Z28, 2SSRS 2010 M6 Join Date: Sep 2009
double clicking puts you into competitive mode and traction control is still on just at a reduced level. Hold it down for 7 secs to turn everything off, traction control and stability control.
12-19-2009, 09:21 AM | #9 |
Drives: 10' 2SS/RS M6 SUPERCHRGED BUMBLEBEE Join Date: Jun 2009
Ahh crap this happened to me last night: I was in competitive mode and revved to about 5000rpms then dropped the clutch and the clutch seemed to be stuck halfway to the ground. It wouldn't go back to normal till i drove it about a hundred feet then I got the awful clutch smell that the M6 Camaro likes to share. Does anyone know why? Isn't the Camaro supposed to be able to do that in competitive mode which they call "Launch Mode?" Someone please inform me why my car is doing this! Thanks so much....
Ordered Bumblebee 10/15/2008Part of the Family 6/11/2009 #11423
My Bumblebee to Superbee build story...http://www.camaro5.com/forums/showthread.php?t=105163 Superbee's 536hp Dyno Run...http://www.youtube.com/watch?v=AE7wePluPAc |
12-19-2009, 10:26 AM | #10 |
VETT 4 5
That's exactly what happened to me.
But like you state - double-click Competitive mode should enable Launch Control. Ironically, the computer is supposed to be programmed specifically for drag racing, yet it obviously doesn't work. Seriously screwed up is more like it............ I'll try the single click vs. 7-second suggestion. There's nothing in the manual about holding for 7 seconds. Very interesting how it details Launch Control though.... |
12-19-2009, 11:59 AM | #11 |
Could GM have set it to do this to prevent people from doing burnouts?
12-19-2009, 12:08 PM | #12 |
So-Cal Race team!!
Come on guys on click on the button and hammer down ....My has no prob spinning the wheels. But the comp mode I have never used Im old school I like to have control of the wheel spin.
WE RACE DEEP!!
BBK Intake, Flowmaster AT cat back Barton shifter,Painted stripes,,Heritage grill,LED DRLs, Smokin Tires!! Last edited by ddunerider; 12-20-2009 at 01:05 PM. |
12-19-2009, 01:29 PM | #13 |
Drives: Imp.blue, tuned,cold air,magfl, Join Date: Oct 2009
I'M HAVING THE PROBLEM ALSO, PUSHING ALOT OF HORSE POWER, BUT WHEELS NOT SPINNING.
BOSS |
12-19-2009, 01:55 PM | #14 |
Drives: Blk/Blk 2018 Sierra SLT Join Date: Dec 2006
If your trying to do a burnout while in comp mode it seems like youd be confusing the computer and thats why its not working. Comp mode is designed to control the wheel spin to get you a better launch
Similar Threads | ||||
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow | KILLER74Z28 | General Automotive + Other Cars Discussion | 25 | 07-22-2011 10:51 AM |
All season tires on RS??? | iyam_lorne | Wheels and Tires Talk Sponsored by The Tire Rack | 6 | 10-07-2010 09:25 AM |
My Lingenfelter Camaro Build | Speed74SS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 244 | 10-08-2009 10:00 PM |
Nitrogen in tires | 1fine79 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 53 | 09-29-2009 02:39 PM |
