09-15-2014, 09:53 AM | #1 |
D1 or P1 procharger?
I want 700 whp and I'm doing a LS9 cam.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
09-15-2014, 10:41 AM | #2 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
We never seem to stop wanting more so I wouldn't go smaller than the d1.I would get a proper cam before I spent the labor on a ls9 cam tho...
09-15-2014, 11:16 AM | #3 |
This if you are stuck on prochargers.
Nick
Corvette Z06 -1200ish rwhp |
09-15-2014, 01:35 PM | #4 |
Internet Car Tech
Drives: 99 formula Join Date: Feb 2012
d1, headstuds , ls9 gaskets and ls9 cam and you should be damn close .
09-15-2014, 02:01 PM | #5 |
No reason to pull heads to make 700rwhp. IMO no reason to put a ls9 cam in if you are going through the effort to put a cam in it.
Nick
09-15-2014, 02:06 PM | #6 |
Seems LS9 cam is a common bang for your buck and is easy on valvetrain. Plus GM has a lot of R&D on their cam.
09-15-2014, 02:08 PM | #7 |
ЯєŧąяĐ Єl¡m¡иąŧøя ™
D1 and a real cam
09-15-2014, 02:09 PM | #8 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
D1sc is good for 925 hp (give or take) p1sc 825 (give or take). I have the p1sc I'm going to test it's limits this winter. And don't worry about a "real cam" there's several over 900 whp with that cam you'll be just fine.
09-15-2014, 03:07 PM | #9 |
09-15-2014, 08:21 PM | #10 |
Svt lol
09-15-2014, 09:35 PM | #11 |
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Those are capable numbers rated at the crank. Won't do that to the wheels. Good luck finding a D1 making over 850rwhp
09-15-2014, 09:40 PM | #12 |
And good luck finding one doing near that on a cam that small. I think what he meant was turbo cars are making 900+ on ls9 and baby cams. Blower cars, not so much.
Nick
09-15-2014, 09:42 PM | #13 |
Drives: '11 Camaro Supercharged Convertible Join Date: May 2014
To get those numbers at the wheel, you're looking at cam, fuel pump, injectors, tons of meth and nitrous. It's been done on the Vortech/Paxton side with the 1500 so it's easy to assume a Procharger can do it with the proper setup. I had a Paxton 1500 which is equivalent, and without nitrous, I made 811 at the wheel.
2011 Triple Black SS convertible, LSX 427, PRC 260cc heads, Callies Ultra Billet Rods, Wiseco -20 cc piston, Callies Dragon Slayer crank, Strange Dana 60 rear w/3.73 gear ratio and driveshaft, Pfadt coilovers, Pfadt sway bars, Pfadt trailing arms, Pfadt tie rods, Pfadt subframe bushings, Vortech YSi with wastegate and twin BOV, Haltech ECU, Mantic 9000 Twin Clutch, ALKY control meth system with dual nozzle, Squash twin fuel pumps, ACS T3 ports, VIS Terminator Hood, Seibon ZL style lip.
09-15-2014, 09:42 PM | #14 |
Drives: 10 ABM 1SS/00 Z28 Conv/14 SumWh 2LT Join Date: Apr 2009
Stock cubes, cam, D1, 85# injectors, pump, meth injection, a very safe 8.7lbs of boost, 697 to the tires
1 SS/RS 6Sp White Rally Stripes
