Old 09-09-2013, 09:14 AM   #1
73camarolt
73camarolt's Avatar
Drives: 2002 Camaro SS
I NEED A DRIVER MOD!!!!
So I went to the track again and only pulled out a 13.3. Car is full exhaust with gears. It traps like a 12 sec car but with a 2.2 60' it's hard to get there. I tried launching, couldn't really get it to "move out" of the hole. Tried slipping the clutch a little but with a already weak clutch and a low rpm had the same problem. I never tried slipping it above 3k which may have been the sweet spot. This car is a 12 second car all day. Was trapping consist 110mph. Plus I missed third about 3 out of 7 runs which doesn't help. Any suggestions? I'm going back in about a month I will be tuned but on the stock clutch. Really want 12's this year.
2002 Camaro SS- BTR Stage 3, 799 Heads, Bolt on's Tuned by John at Broadview Automotive.. 420hp and 400tq
73camarolt is offline   Reply With Quote
Old 09-09-2013, 07:21 PM   #2
insidethreat07
insidethreat07's Avatar
Drives: 2001 Camaro 3.8
sticky drag radials and pray your 10 bolt wont blow up in the first pass lol
Then when it does buy a 12 bolt or 9'' lol
2001 Camaro V6
2016 Camaro 2SS
insidethreat07 is offline   Reply With Quote
Old 09-09-2013, 08:08 PM   #3
73camarolt
73camarolt's Avatar
I wish I really do. But I already need a clutch so that's about a grand right there. I can't afford that and a rear..
Old 09-09-2013, 09:52 PM   #4
insidethreat07
A clutch is that much?
2001 Camaro V6
2016 Camaro 2SS
Old 09-10-2013, 11:45 AM   #5
73camarolt
73camarolt's Avatar
Yea. Either do Ls7 $600 or monster stage 2 $680. gonna try and catch it on sale. Then. Tick adjustable master cylinder is 325 so maybe alittle under,
Old 09-17-2013, 01:31 PM   #6
xXSilencerXx
Butter Bar!
xXSilencerXx's Avatar
Drives: 2011 SS, 1998 Trans Am
If you don't want to spend $300+ on the adjustable master, look into the drill mod first, and there's a write up out there on how to modify the stock on to make it adjustable. I'm in the middle of a T56 swap right now and will be running the drill mod first and then move from there.
As far as the driving style I had similar issues with the 5th gen. Tires will help out a ton and getting the suspension set up right too. I ran into come out too hard and spin the tires, or bog trying not to spin them. Best I was able to get was 2.0 60', while the TA was hitting 1.9 just hammering it off of the line with a stock stall.
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension
2004 GSXR 1k, Matt Mladin Edition
xXSilencerXx is offline   Reply With Quote
Old 09-17-2013, 07:02 PM   #7
OVRKILL
OVRKILL's Avatar
Drives: 01SS
Your issue is in the 60'.....like Insidethreat said, stickies and launch it!
'01SS - RHS 460....fed by 8 little throttle bodies
Kinsler / Fikse / RHS / Mast / MWC / Kooks
OVRKILL is offline   Reply With Quote
Old 09-17-2013, 07:48 PM   #8
73camarolt
73camarolt's Avatar
Stock rear and no money for a built one is the reason I'm not really launching it. I wish I could trust me haha.
