12-30-2015, 11:14 AM | #1 |
Drives: 2010 Camaro SS RS L99 Join Date: Jan 2012
Any bagged camaros on here??
Thinking about bagging my camaro!
12-30-2015, 02:31 PM | #2 |
Drives: 2015 2SS/RS vert, Spring Green Edtn Join Date: Jun 2014
Will that be paper or plastic?
2015 2SS/RS vert, Spring Edition Green Flash (2015 - present)
2014 1LT vert, Blue Ray Metallic (2014 - 2015) |
12-30-2015, 02:48 PM | #3 |
Drives: 96 camaro Join Date: May 2009
Lol.
12-30-2015, 02:49 PM | #4 |
Drives: 2014 Camaro 2SS 1LE NPP Join Date: Nov 2013
If plan A is to bag your Camaro ... go with plan B.
My thoughts on some things:
12-30-2015, 03:01 PM | #5 |
Drives: 2010 1LT & 2016 Cadillac CTS V6 Join Date: Apr 2015
12-30-2015, 03:07 PM | #6 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
12-30-2015, 03:13 PM | #7 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Hmm, take an awesome handling car and ruin that with airbags. Probably should find an old 60s boat for that. Then you are improving on stock not degrading it.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
12-30-2015, 08:37 PM | #9 |
Actually with bags you can litterally adjust anything. A lot of cars are bagged. It's good quality and you can adjust it for whatever you are planing on doing that day
12-30-2015, 10:56 PM | #10 |
Drives: 2011 1SS/RS LS3 Join Date: Dec 2012
I agree! You an adjust a bagged car as needed depending on if you're going to a Bernie Sanders convention, a Vape show, instagramicon, or a Justin Bieber concert.
CAI intake, apex scoop, Vmax ported TB, MGW short throw, BMR 1" springs and sways |
12-30-2015, 11:51 PM | #11 |
Drives: 2013 1SS LS3 Join Date: Feb 2014
12-30-2015, 11:57 PM | #12 |
12-31-2015, 12:30 AM | #13 |
Living Life in MPH.
Bags are for groceries
12-31-2015, 12:35 AM | #14 |
Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
Idk for me I rather go coilovers than bags. I have friends that have bags and it looks cool, but it just takes up trunk space. Unless you put the tank and compressors where the spare tire goes so it is hidden, but people like to show off there setup.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
Tags |
bags camaro |
