11-04-2012, 01:22 AM | #1 |
ZL1 - The Legend Returns!
Drives: 2013 ZL1 Camaro Join Date: Jul 2012
Fuse Pull in California..91 Pump Gas...Now Slower??
So I've read many post on the Fuse pull and something else I've read is that GM recommends 93 octane or higher. In CA we only have 91 and doing the fuse pull with 91 in the tank MAY put the car in a lower map if the car was shipped with 93.
I did the fuse pull on my 2013 ZL1 with 1500 miles on it and swear it feels slower. I don't feel that is has the pull it used to on the freeway or top of the gears. So, if its true that 91 octane can possibly be effecting this, i might not be just imagining this. I found a table on 76 Gas Stations that show mixture ratios. I have a 76 close that sells 100 octane. It says if i mix 5 gal of 100 with 10 gal of 91 the octane results will be about 94. Im going to try this, then drive home and do the fuse pull and see what happens. Anyone else have any input on this? Thanks |
11-04-2012, 02:16 AM | #2 |
Drives: Exige, Miata, Ghia Join Date: Jun 2011
Which 76 sells 100 octane in SJ?
11-04-2012, 02:26 AM | #3 |
[COTW- Never!]
Drives: Slothy; Sloth-like Join Date: Sep 2011
why not just wait, do 100 octane, and see if there is a definite change at all??
go big or go home
11-04-2012, 08:54 AM | #4 |
Drives: 2011 camaro 2ss/rs rally yellow L99 Join Date: Nov 2011
Never know you had to do a fuse pull on a zl1 too. Is it auto or manual.
- Airaid cold air intake - Kooks 1 7/8 long tube headers
- Kooks high flow cats - Borla atak 2.5" cat back exhaust - Dyno tune - AFM delete - 94 octane tune - Vitesse paddle shifters - Blacked out rims - Costum painted engine cover - T3 stripes - GM locking gas cap |
11-04-2012, 09:05 AM | #5 |
Drives: '86 Monte Carlo SS Join Date: Nov 2010
San Jose
Damar Petroleum 76 3010 Almaden Expwy (at Foxworthy Ave) (408) 264-3661 Open 24 hours Sunoco GT 100 octane unleaded at pump confirmed 11/30/11 $7.25 Saratoga (San Jose area) Saratoga 76, Ratra Enterprises Incorporated 14395 Big Basin Way, Saratoga, CA 95070, (408) 867-0551 100 octane unleaded at the pump 10/14/12 $8.99 |
11-04-2012, 09:29 AM | #6 |
Banned
Drives: 2012 Camaro 2SS/RS Convertible, IBM Join Date: Jun 2012
There are many threads on the "fuse pull". I tried it with my car and couldn't tell any difference.
A person on this site, a GM technician showed the schematics of the fuse pull and showed it to be worthless. I concur, both by looking at the electrical routing and trying the fuse pull, which again, did nothing. |
11-04-2012, 09:36 AM | #7 |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
11-04-2012, 09:50 AM | #8 |
There was a very long thread on the ZL1 forum about this, everyone was saying that they did it an felt a difference. That said, they were all NOT located in California. Then one user commented on the 91 gas in CA and that it would set the car in the lower octane table. A response showed an insert from the GM Service book that said if the car is in the lower octane table, pull the fuses 5 and 20 to reset the ECM and then tell the customer to use 93 or higher gas.
The thread later said that gas below 93 octane can put the car in a lower octane table which has less timing thus limiting the power a bit. So my thought was to up the octane with 100 and then due the fuse pull again. Im going to try it and see what happens. Dont get me wrong, the car is still very fast, maybe I'm just getting used to the power or maybe there is actually something going on with the ECM. |
11-04-2012, 10:01 AM | #9 | |
11-04-2012, 11:44 AM | #10 |
....soooo is it a manual or auto? cus on the ss's the fuse pull thing is for the auto trans, the manual isn't effect by the octane settings from what I recall...
11-04-2012, 01:40 PM | #11 | |
SoCal Mayhem
Drives: 2010 Camaro 1SS/RS Join Date: Aug 2008
http://www.camaro5.com/forums/showthread.php?t=38964
11-04-2012, 01:58 PM | #12 | |
11-04-2012, 03:37 PM | #13 |
Thanks guys. I have a M6
11-04-2012, 06:29 PM | #14 | |
Drives: 2011 Cyber Gray 2SS 6 speed Join Date: Jan 2012
I tried the fuse pull 4 times over the 10 months I've owned my car. I never felt any change in power. The first couple of times I questioned whether or not I used all the suspected 87 octane. But all 4 times I filled up with 93 octane. I never went down to anything less than a half of a tank before I refilled with 93. But after 10 months I give up. This myth is busted.
And yes I pulled 5 and 20 and let it sit overnight. Bob Quote:
